08-08-2015, 09:11 PM | #1 |
Engine problems after body shop?
I just got my truck back from the body shop. Now it misfires quite a lot, mainly after stopping and in 1st gear. Its a really muffled "pufpufpuf".Eevery once in a while I hear a slap noise and It'll almost die. Suggestions? its got new plugs and wires from last year.
08-08-2015, 09:35 PM | #2 |
Re: Engine problems after body shop?
this also happens more when the engine is cold and it doesn't completely stop when its warmed up
08-11-2015, 12:28 PM | #3 |
Carb or FI? Mine will puff back through the carb slightly sometimes. I think I need to fine tune the choke settings and possibly tweek the timing a degree or two. Of course fuel injection would not have choke issues.
08-11-2015, 01:00 PM | #4 |
Could the air filter be full of bodyshop dust?
08-11-2015, 02:05 PM | #5 |
depends on how long it was at the shop. Might be bad gas.
08-11-2015, 02:10 PM | #6 |
At the body shop.
New plugs, probably loaded up from idling about
" That didnt make it any newer " " Dont antique the equipment " |
08-11-2015, 02:15 PM | #7 |
If they did anything around the engine area, they might have knocked a few plug wires loose and installed them back in the wrong order. Or pulled loose a vacuum hose or two.
