Moderator
![]() ![]() Join Date: Aug 2011
Trans Mount Question
I am trying to fit my engine transmission in the 64 Step side Short bed and have a 2X4 board across the lower frame rails holding up the trans under the trans mount. It’s not hitting the body/tunnel but just barely, it clears.
What type of trans crossmember mounts would come close to this (automatic tranny), does anyone know? I’m going to use a column shift setup. Thanks. ![]()
Master Chief, US Navy, Retired 1964 C10 Step-side Short Bed - In Progress 2009 2500HD Duramax LTZ 1948 GMC Panel 1956 Big Window Stepside 1953 5 Window Chevy Stepside 1932 Coupe New Seat Foam for Bench Seats? Last edited by The Rocknrod; 08-11-2015 at 04:38 PM. |
Custom Truck Lover!
Re: Trans Mount Question
I bought the kit from Performance Online.
Squarebody guy |
Moderator
One foot in front of the other
![]() Join Date: Aug 2008
Quite a bit of info in the FAQ section.
Moderator
Not enough on this question. Already checked. Thanks though.
#6 | |
Custom Truck Lover!
Squarebody guy |
Moderator
I am using their engine mounts thats why I asked. "If" I need to raise the rear of the tranny I can use an aluminum spacer/block I suppose.
I'm attempting to match the pinion angle so I will have to use a 6 degree shim in the rear since (lowered) I'm using the stock trailing arm crossmember. Thanks ![]()
