#101 | |
Re: My caster mod (with pictures)
The unmodified side on crakarjax's OE arms set-up is centered (top of pic). The side w/the modified cross shaft is no longer centered (more front side overhang).....
#102 | |
Circumference of a 9" circle would be: 3.14 * diameter = 28.26" degrees per inch moved (around that circle) would be 360 / 28.26 = 12.7 This ignores the cosine error, of course, making my calculations a little larger than we'd actually get. So, compared to a vertical spindle... moving 1.0" equals 12.7 degrees caster moving .75" equals 9.5 degrees moving .5" equals 6.35, etc.... |
#103 |
Uhm yeah, just goes to show how bad I am with Geometry. Picklito, are you sure about those numbers? Using my truck as an example again, my LF has 2.7 degrees of positive caster. According to your numbers just moving the index .5" would make my caster 9.05. That couldn't be right. Or am I reading it wrong and total caster would be about 6.35?
Nick Carter 1967 C10 Short bed Fleetside Project Cheap Thrills! 2WD C10 Modern/Performance Alignments Easiest Alignment Ever! |
#104 |
No, you're right that you'd have 2.7 + 6.35 degrees of caster. You're also right that nobody is getting that much caster increase. The math is right, the numbers are right, but the model it's based on is poor and doesn't really represent what actually happens in the truck...
We're assuming the lower ball joint is moving around the circumference of 9" circle. It actually moves straight forward. And we'd need to use the center-to-center distance between ball joint pivots. If that's (just guessing) 12" rather than 9", then the circumference is 37.68" rather than 28.26" and moving the control arm forward by .5" produces 4.77 degrees of additional caster rather than 6.35. Then add in the (small but real) cosine error and you'd get slightly less. So, 2.7 + 4.77 = 7.47 degrees of caster in your case before removing the cosine error. That's probably closer? |
#105 |
Crakarjax,
In this photo of your drilled hole, how far is the center of the hole from the end of the shaft? It looks FAR! In light of the recent discussion about all the different hole locations we're finding... did you end up farther than 2"? |
#106 | |
If I recall, the center of that hole is at 2.25"
1968 LWB C20 / AC / Wood Bed |
#107 |
#108 |
x2.
#109 |
SCOTI,
You mentioned previously that you didn't have to trim a whole bunch. Do you remember where you put the hole from the end? |
#110 | |
2". See post #273 & 274 in the above thread for dimensions w/pics.....
#111 |
Well, originally I thought I needed to go .75" from my replacement shaft holes and it seemed like a lot to clearance -- then I realized they were already .25" from stock so I only moved .5" which should give me significantly less to shave. I haven't clearanced yet but I'll take before/after pics to see exactly how much you'd need to trim for 2.25" out.
#112 | |
#113 |
Mine arrived today. Moog K6147. Haven't yet measured the one in the truck.
#114 |
Waiting to see if I order them !
#115 |
Interesting, my stock shafts are 1.5", replacements are at 1.75", and so I drilled my holes at 2.25". Are most stock shafts drilled at 1.25"?
#116 |
So, I trimmed my arms with 2.25" to center holes and didn't have to take all that much off. I did not trim my crossmember at all. (see pics)
I have a question that is sort of unrelated to this caster mod though (sorry to be off topic) -- if you look at the pics of my lower arm with the bumpstop on (pic 3) vs removed (4th pic), it looks like there's no way the shock could be mounted at that much droop because the shaft would need to go through the crossmember. Am I right? Obviously this is affected by moving the control arm forward... I removed the stop because I read that was necessary when bagging to get max drop. I'm planning to bag with plates and I can't see ever dropping that much just due to the thickness of whatever bag I use. How much clearance between the lower arm and the crossmember can I expect when aired out with that kind of setup?
#117 |
Are these the ones at 1.75"? Now I'm surprised that my Moog's are at 1.25". Oh well, doesn't really matter since I'd be drilling anyway. However... for stock replacement parts... what the heck is going on here? I've never seen so much variance in other parts over way too many years. Can you imagine if a non-hobbyist had to have just one side rebuilt for some reason? He could have alignment issues forever and I GUARANTEE YOU that the average shop tech wouldn't be able to find it!
Overall, thanks to the awesome people on 69-72 we've uncovered a lot of good info. Pretty clear now why some are having so much interference. If a guy happened to have 1.75" shafts and tried to do the "3/4-inch mod" he'd have problems. Sounds like, regardless of where we start, 2 to 2.25" is where we want to land (with the real goal of about 7 degrees of caster). Awesome post and pics, above, by the way. Super helpful. Unfortunately, I'm still weeks away, so I won't be able to post what my stock shafts have for quite a while. Looking at the truck, though, I'm gonna like having the wheel farther forward, despite how small that will be. If I were a better welder, I think I'd cut the lower arm and re-weld the ball joint mount farther forward. That seems like a better overall mod. I'd like to keep the spring as straight as possible. |
#118 |
Yes those are the ones at 1.75" from the factory.
This pic shows how my shock mount points right at the crossmember when down all the way (right side). I'll probably run plates and cups though so aired out would likely clear (left side) assuming that sandwiching 3" of lumber in there is a good gauge.
#119 |
When you shift the lower arm forward, the shock isn't going to align w/it's original position. You'll need to get things mocked up & either space the lower mount back and/or make a new upper mount.
#120 |
This is just my opinion, having done this mod on my truck...
It seems to me that the amount of caster increase is really hit & miss when using control arms with the steel threaded bushings. A couple revolutions of the control arm shafts will make quite a difference plus or minus depending on which way you turn. I believe that to get a consistent caster change, you have to be careful to "centre" the shafts in the threaded bushings. Wouldn't the rubber bushing style be much more consistent? My .02
* My 63 C10 SWB Fleetside (converted to BBW): http://67-72chevytrucks.com/vboard/s...58#post6851558 @johnny_lamebridge on Instagram
#121 | |
![]() Join Date: Mar 2005
It might become an issue if you go more than .75". Maybe?
Check out my latest endeavor: https://roundsixpod.com My build threads: '55 Chevy: http://67-72chevytrucks.com/vboard/s...d.php?t=247512 '64 C-20: http://67-72chevytrucks.com/vboard/s...d.php?t=446527 |
#122 |
What Johnny said.
I haven't done my front end rebuild yet, still collecting parts. But knowing how they go together I think he makes a very important point. That, and the variance we've seen on the cross shafts that we're pulling out of these trucks. We just have to be careful verifying our starting point and how we put it back together if we want a good caster mod. |
#123 | |
#124 |
You're right that it's possible to have the shaft off-center, but it's not that hard to ensure that each bushing is threaded an equal number of revolutions per side to keep it centered.
#125 |
Sorry for the long delay, been out to sea. Here are my stock measurements, and then my new ones.
Project Roxy... Shes Bad, Low, and Blown... http://67-72chevytrucks.com/vboard/s...d.php?t=673333 |
| Bookmarks |
