Old 08-12-2015, 07:43 PM   #1
tk1251k
tk1251k's Avatar
Motor mounts and freeze plugs
OK time to start on the 1972 350 motor mounts and freeze plugs. I have read a tremendous amount on here about the process. Some make it sound easy others a real pain. Too me appears to be the latter. Should one side be done at a time?Mine is totally stock with air. Does the mount need to be loosened before jacking with a 2x4 under the oil pan? looks to be a real pain but I need to do it. Thanks for any info.
tk1251k is offline   Reply With Quote
Old 08-12-2015, 08:06 PM   #2
GASoline71
"I ain't nobody, dork."
GASoline71's Avatar
Re: Motor mounts and freeze plugs
I don't know about jacking up the engine from the oil pan... I'd lift from the top with a picker.
No matter what way you do it... it ain't gonna be an easy task.
Gary
'cuz chicks dig scars...
I would never rebuild a 305.
Old 08-12-2015, 08:17 PM   #3
tk1251k
tk1251k's Avatar
I am not looking forward to it but it has to be done. I noticed underneath it today which is off subject but the tie rod is mighty close to the oil pane like less than a quarter of an inch. Is that normal?
Old 08-13-2015, 03:00 AM   #4
mike16
its not tough to do but it is a time consuming PITA.
a little tougher on the manualy tranny trucks
Id rather do it to a v8 3 on the column then a AC truck
dont do one side at a time. lift the whole engine up remove the mounts and then the freeze plugs. re install.
If your tranny is a manual. unbolt the bell housing mounts as well
as if your not having enough fun yet... there are two freeeze plugs behind the fly wheel as well
mike16 is offline   Reply With Quote
Old 08-13-2015, 06:29 AM   #5
tk1251k
tk1251k's Avatar
You had too mention the two behind the flywheel I had almost blanked them from my mind lol.What needs too be loosened before jacking the engine just the one bolt each side that goes through the brace tower that the motor support rest on?
Old 08-13-2015, 10:50 AM   #6
cooperhw
cooperhw's Avatar
It's a pain in the *** to get the new motor mount bolts to line back up for some reason. Little work, but the best way I found to get em bolted back up is to loosen all the (6) bolts that hold the engine perches to the frame. (Yeah, I know, PITA) but I have spent hours trying to get bolts to line up without doing this.
Freeze plugs; I always put them in the freezer the night before installing them. They actually shrink just the slightest (miniscule) amount and make for easier install. I take em out of the freezer one at a time and install them.
"Life is too short to drive a boring vehicle".
Later,
Wayne
cooperhw is offline   Reply With Quote
Old 08-13-2015, 03:33 PM   #7
tk1251k
tk1251k's Avatar
Those perches will need too be removed to replace the freeze plugs anyhow so best not to tighten them down until the new mounts are lined up I suppose. THis is a very tight and greased up area to work in.
