Old 08-16-2015, 07:33 PM   #1
Jimal
Jimal's Avatar
I think I figured out my handling problem
I've been chasing a weird handling problem for about as long as I've had the truck on the road, and although I've replaced some really crust old parts (cab mounts, transfer case mounts), the problem has never really gone away. I've been getting some driveline wrap when I first take off from a stop (the rear of the truck feels like it is lifting) and I get a weird seat of the pants wiggle on decel.
I went to look at something else under the back of the truck and stumbled into this.
Note the gap between the leaf spring and that big girder looking perch. I might soak these things in deep creep and see if I can tighten them down, but I'm sure they're not going to take that well. I'm looking at the parts schematic on LMC and that piece doesn't appear and the u-bolts they show are much shorter.
Thoughts?
Jimal is offline   Reply With Quote
Old 08-16-2015, 07:50 PM   #2
jonzcustomshop
1961 crewcab
jonzcustomshop's Avatar
Re: I think I figured out my handling problem
I just go to a local trailer/spring shop and have them bend me new U bolts, I don't have to wait on shipping, and the cost is about the same...although the cost is expensive... the bolts for my sub with the 4 inch lift were about $70
make sure you bring an old one with you to compare to the new one they bend for you (so they can visualize what you want.)
** my stock 63 k20 has that same lift block, I am sure it is stock.
Old 08-16-2015, 07:56 PM   #3
Jimal
Jimal's Avatar
We actually have one of those near by. And since I'm not finding anyone yet online who has an application for a '65 K10, my options might be limited.
Old 08-16-2015, 08:42 PM   #4
padresag
that is the way to go. just get them made. the old ones can more than likely get stretched a little and a little wear in the spring leafs over 50 years can do it. it may be simpler just to cut them off instead of struggling to take the nuts off. your not going to use them again. check the centre bolts in the springs while you are there
http://www.lmctruck.com/icatalog/cbe/full.aspx?Page=37
ron
padresag is offline   Reply With Quote
Old 08-16-2015, 09:22 PM   #5
bhc41051
bhc41051's Avatar
My 62 has a shim between the lift block and the springs, I assume it has something to do with the drive-line angle. It looks to be OEM
bhc41051 is offline   Reply With Quote
Old 08-16-2015, 09:35 PM   #6
evan396
Jimal, you should run down to Danbury springs and get a new set, when we removed ours the thread's were shot. You should also remove the block's as padresag suggested, we had some rust built up under the block and on top of the block between the Axel pad and leaf springs. Evan
evan396 is offline   Reply With Quote
Old 08-16-2015, 10:13 PM   #7
Jimal
Jimal's Avatar
I might try tightening them first to see what happens. I can always cut them off if they won't turn.
Old 08-16-2015, 11:18 PM   #8
66Gilbert
1966 Crew Cab & 4X4 Fanatic
66Gilbert's Avatar
I doubt you will be able to tighten them up any with all the dirt and rust that is trapped by the bottom bracket all those years. Even here in Arizona I had to remove the U-bolts and chase the threads with a die in order to get them to tighten up. Being from the area you are from and the way the pictures look I agree with the others on replacing the U-bolts and cleaning the lift blocks and springs.
66Gilbert is offline   Reply With Quote
Old 08-17-2015, 01:34 AM   #9
1971 GMC SHORTY
1971 GMC SHORTY's Avatar
Thoughts?
I have That Same Gap on mine
1966 GMC K25 V6 351E Original Utility Truck
2000 C3500 Hot Rod Utility Truck
2003 ROAD KING 100th 124ci 6 Speed
145CI M/P Pro Street FXR
2002 FXDP
2007 2500HD DURAMAX. DD
Studio Teamsters / Mechanic
Retired GM Master Tech 20 Years
Retired Ford Tech 15 Years
1971 GMC SHORTY is offline   Reply With Quote
Old 08-17-2015, 02:00 AM   #10
BigDan3131
BigDan3131's Avatar
I've been looking into new U Bolts and from what I have read it says to never reuse them because they are torqued on and stretch like rod bolts do.
Custom Painter/Restoration Specialist
1965 GMC 3/4 Ton LB SOLD?
1964 Chevy El Camino in full restoration
1991 Chevy S10 288K+ miles 2nd Owner SOLD
2020 RAM 1500 Warlock
BigDan3131 is offline   Reply With Quote
Old 08-17-2015, 09:38 AM   #11
luvbowties
luvbowties's Avatar
Smile Re: I think I figured out my handling problem
Look how close each of bhc41051's spring leaf hugs its adjacent one(s).
Sam
luvbowties is offline   Reply With Quote
Old 08-17-2015, 10:52 AM   #12
evan396
Almost forgot jimal, look closely at the blocks. We had at least three cracks in the rear one's. Dad brought them to work to get the welder to grind out the cracks and weld them back up.Evan
Old 08-17-2015, 11:17 AM   #13
Jimal
Jimal's Avatar
Will do. This will be one of those "check everything while you have it apart" opportunities.
Old 08-17-2015, 11:18 AM   #14
Jimal
Jimal's Avatar
Between the leafs or between the bottom leaf and the block? because I don't think either one is ideal.
Old 08-18-2015, 09:02 PM   #15
Jimal
Jimal's Avatar
https://youtu.be/mo6RBeKChuQ
This is what I found when I went to check the u-bolts. I'm seriously lucky nothing bad happened and more than a bit surprised things got this loose. Everything was nice and tight when I checked it last summer while I was working on the rear brakes and shocks. New u-bolts have been made and I'll pick them up in the morning.
Old 08-18-2015, 10:00 PM   #16
earl84
Holy crap!! Glad it didn't all fall apart on you.
earl84 is offline   Reply With Quote
Old 08-19-2015, 03:47 AM   #17
Jimal
Jimal's Avatar
That makes two of us. It definitely wasn't like this when I started.
Old 08-19-2015, 06:35 AM   #18
PGSigns
PGSigns's Avatar
One of the things we have found working on the old cars and truck around here is there can be lot of rust between the springs in the stacks and that causes them to not work as they should. I would pull the spring out and pull it apart and clean and paint the leafs and rebuild the stack when you do the ubolts. Also look for cracks in the center where the bolt goes through.
Jimmy
60 to 66 Chevy and GMC window decals
http://67-72chevytrucks.com/vboard/s...d.php?t=661131
Good friends, good food and a hotrod what else do you need?
1966 BBW long fleet Daily driver
1965 BBW short fleet Sold and going to a good home
1965 Suburban
2003 3500 Duramax
2005 Ultra Classic
PGSigns is offline   Reply With Quote
Old 08-19-2015, 05:15 PM   #19
mattbert56
mattbert56's Avatar
These are the blocks that came on my k20 frame. The U bolts had to be snuggled up on mine a little after 50 years.
Well that didn't go as planned.
1965 k20 buikd thread: http://67-72chevytrucks.com/vboard/s...=628346&page=6
mattbert56 is offline   Reply With Quote
