Old 08-17-2015, 03:06 PM   #1
dmkilgo
94 k1500 350 vibration
I just bought a 94 k1500 with a rebuilt 350 in it, and I'm trying to figure out why I'm getting some vibration around 55-60 mph. After playing with it some, I've noticed that the vibration stops as soon as I take my foot off the gas pedal (but I'm still going the same speed), so I'm thinking it must be something more related to the RPM at 55-60 mph in overdrive than the speed. Since it stops when I take my foot off the gas, I'm assuming that it's not the tires or driveline, because they are still spinning at the same rate. Could it be the engine itself? If so, what do I do to correct it? Anyone have any ideas? Thanks.
dmkilgo is offline   Reply With Quote
Old 08-17-2015, 08:38 PM   #2
Kudzupatch
Kudzupatch's Avatar
Re: 94 k1500 350 vibration
In high school I drove a Bronco that would eat u-joints. That was the sign one needed replacing. A vibration under load but I don't remember the speed range. If it were mine I would start there.
Kudzupatch is offline   Reply With Quote
Old 08-17-2015, 10:09 PM   #3
pwdcougar
pwdcougar's Avatar
X2
Check the U joints.
Paul
"You know that little thing in your head that keeps you from saying things you shouldn't? Yeah well, I don't have one of those"
1969 Mercury Cougar Standard 4 speed
1969 Mercury Cougar XR7 convertible
1970 4WD Chevrolet Suburban
1997 4WD Chevrolet Silverado Extended Cab Short Bed (purchased new January 1997)
pwdcougar is offline   Reply With Quote
Old 08-18-2015, 09:30 AM   #4
sntrym95
sntrym95's Avatar
X3. It's almost certainly the u-joints. After you replace them, have the driveshaft checked for balance. it's worth the extra $.
Mike
sntrym95 is offline   Reply With Quote
Old 08-18-2015, 10:05 AM   #5
Keith Seymore
Keith Seymore's Avatar
x4. Driveline disturbances are "torque sensitive" (that is, they vary based on load).
K
Chevrolet Flint Assembly
1979-1986
1986 - 2019
Keith Seymore is online now   Reply With Quote
Old 08-18-2015, 11:25 AM   #6
dmkilgo
That seems pretty definitive. Thanks for all the replies. Not sure how soon I'll be able to get it done, but that is where I'll start. Might get to it Saturday. I'll try to remember to update on whether or not that fixes it.
Old 08-18-2015, 01:59 PM   #7
mountie
mountie's Avatar
Do you only hear a vibration? Or do you also feel it?
In my transmission, during the early days, I had a bad LOCK UP in the torque converter.
That causes a vibration.... ( not really a noise)....
'70 GTO Midnight Blue
'88 GMC Sierra SLE 392,000 miles-(2018) sold to Classic car shop in Germany.
'93 Cadillac STS Black
'93 Mercedes SL 500 Teal
'86 Yamaha FZ750 - 15,000 RPM
'86 Yamaha FJ1200 - Criminally Fast
2016 Ferrari 488 GTB, I drive it - don't own it.
'05 GMC Yukon XL , SLT 4wd ( just purchased 2018)
mountie is offline   Reply With Quote
Old 08-18-2015, 02:04 PM   #8
dmkilgo
You hear it pretty loudly, and feel it a little bit.
Old 09-07-2015, 04:13 PM   #9
dmkilgo
Still haven't gotten to the u joints, but I've discovered another problem. Don't know if it is appropriate to make a new post, or continue the saga on this one, so I'll start here and if I need to make a new post someone please let me know. It feels like my four wheel drive engages, but the front wheels don't pull. I crawled under it and the actuator isn't wired up. It has 3 wires dangling from it. There are also three wires dangling on the other side of the axle that i assume go to it, but one doesn't look like it is the same color so I'm hesitant to hook them up. I also noticed another pigtail (a 2 wire) on the back side of the axle that is hooked up, but has one wire that is almost torn in two. Anyone know what it does? Any advice on how I should proceed with the actuator and wiring?
Old 09-23-2015, 11:23 AM   #10
dmkilgo
Update: 4 wheel drive is fixed. Just wired it back up and all is well. Still haven't had time to install new u joints. The wife keeps assigning me other tasks. Need to get it done though. Deer season will be here soon...
Old 09-23-2015, 07:48 PM   #11
1976gmc20
Those actuators are troublesome
I took out the actuator and stuck a piece of 3/4" PVC pipe about 1" long on the end of the plunger, and then reinstalled the actuator to semi-permanently lock in the front axle.
My pickup is only used for a firewood truck and on local roads, but you can also get a "Posi-Lok" cable control which eliminates all the wiring and the thermal-hydraulic actuator.
Current/past Chevy/GMC trucks:
1958 Chevy C-60; 1965 GMC C-50; 1965 Chevy C-10; 1971 Chevy K-10; 1973 Chevy K-20; 1976 GMC C-20; 1977 Chevy C-10 Suburban; 1980 Chevy K-10; 1989 Chevy K1500; 1991 GMC V1500 Suburban; 2016 Chevy K2500 HD
Other vehicles: 1988 Jeep XJ; 2011 Toyota 4Runner
1976gmc20 is offline   Reply With Quote
1500, 1500 v-eight, 350, shaking, vibration
