![]() Join Date: Oct 2013
1964 Firewall Heater Question
Starting on restoring my 1964 and the firewall has seen some modifications. Need to know if heater area on firewall is stock and or what type of mods may have been made. Photo of firewall is below. If you have a photo of stock firewall with delux heater to post it would be a big help.
Not sure what heater this truck came with, do not believe the heater came with the block-off plate shown in the photo below. It is reported that a heater block off plate was not available in 64'. thanks Les Last edited by aotte1; 08-16-2015 at 09:52 PM. |
One foot in front of the other
![]() Join Date: Aug 2008
Re: 1964 Firewall Heater Question
May help
DPowers,
Thanks for the photos, they help me see how it works. Les |
60-66 Nut
To install the deluxe heater, you will need to remove the lower blockoff plate.
John,
Thanks for the help on Deluxe heater install. From my limited research, looks like lower right firewall hole is where wire harness for fan motor passes through. If correct was their a rubber grommet protecting the wire harness. Les |
60-66 Nut
Yes, that lower hole closer to the engine is where the fan wire passes thru with a rubber grommet.
