Old 08-13-2015, 08:12 PM   #1
67chevy1
67chevy1's Avatar
67 250 with a 3 speed
I haven't taken any pictures of it yet. I haven't even pulled it out yet, but I have a 250 inline 6 and a 3 speed in a c10 long bed that I bought for the cab only. It runs decent not like new by a long shot but runs good enough that I have drove it around the yard a couple times. Not to much as it doesn't have any brakes. It needs a starter but the old one still works it just does a lot of screeching. I would take $350 for the pair or $200 for the engine alone and $150 for the transmission.
67chevy1 is offline   Reply With Quote
Old 08-14-2015, 04:34 PM   #2
drewbert41
drewbert41's Avatar
Re: 67 250 with a 3 speed
Sent a PM
drewbert41 is offline   Reply With Quote
Old 08-14-2015, 04:48 PM   #3
67chevy1
67chevy1's Avatar
I had time to go take picture this evening.
Old 08-15-2015, 10:38 PM   #4
67chevy1
67chevy1's Avatar
bump
Old 08-18-2015, 09:18 PM   #5
Graham57a
Graham57a's Avatar
Would you part with just the air cleaner and stove pipe assembly?
Graham57a is offline   Reply With Quote
Old 08-18-2015, 09:31 PM   #6
67chevy1
67chevy1's Avatar
For right now I would rather keep it as 1 unit, but if I do decide to strip it apart you be the first I contact. I do have to ask. Are you referring to intake and carb as a stove pipe assembly.
Old 08-19-2015, 10:37 AM   #7
michael bustamante
michael bustamante's Avatar
i dont believe 67`s came with stovepipes. Stove pipes are those metal tubes that feed from the air cleaner neck to the exhaust manifold usually
1967custom
michael bustamante is offline   Reply With Quote
Old 08-19-2015, 11:04 AM   #8
67chevy1
67chevy1's Avatar
Oh the heat riser tube, no they don't have the heat riser on them.
Old 08-20-2015, 10:45 AM   #9
Graham57a
Graham57a's Avatar
That was my mistake, it looked like there was one on your motor but I might need a new pair of glasses. Just the air cleaner if you decide to part, thanks
Old 08-21-2015, 02:25 AM   #10
SpaceTruckin
SpaceTruckin's Avatar
What trans is it? Would you sell the driveline?
Bagged 67 C10 longbed
71 Dodge D100 shortbed
SpaceTruckin is offline   Reply With Quote
Old 08-21-2015, 05:34 AM   #11
67chevy1
67chevy1's Avatar
It is the 3 speed. What are you calling the driveline?
Old 12-27-2015, 07:23 PM   #12
rsmarr1982
rsmarr1982's Avatar
You still have the crossmember under the bellhousing?
1969 chevy c10 lwb stepside 250 6 3 ott
1971 chevy c10 lwb 250 6 with power steering 3 ott
1972 chevy k20 4x4 350/TH350 automatic
1978 chevy Malibu 4dr 305 2bbl (all original)
1979 chevy k10 Scottsdale 350/th350 full-time 4wd(daily driver)
rsmarr1982 is offline   Reply With Quote
Old 12-27-2015, 07:29 PM   #13
67chevy1
67chevy1's Avatar
Yeah I still have everything except the transmission
Old 12-27-2015, 07:32 PM   #14
rsmarr1982
rsmarr1982's Avatar
How much you want for it shipped to 44260. If you where closer I'd buy the whole engine.
Old 12-27-2015, 07:44 PM   #15
67chevy1
67chevy1's Avatar
I'll take $25 for the crossmember plus whatever it cost to ship it. Do you happen to know if the granny low 4 speed has the same crossmember as the 3 speed? I'll look tomorrow but I already have a 4 speed 1 out.
Old 12-27-2015, 07:47 PM   #16
rsmarr1982
rsmarr1982's Avatar
I've seen people say they are the same but since you have both if you could take a quick look I'd appreciate it. I will take it for that price.
Old 12-27-2015, 07:48 PM   #17
rsmarr1982
rsmarr1982's Avatar
I'd buy the throttle linkage off the inline 6 too if u still have it. And all the clutch linkage.
Old 12-27-2015, 07:48 PM   #18
67chevy1
67chevy1's Avatar
I'll get a shipping price figure out for you tomorrow
Old 12-27-2015, 07:59 PM   #19
67chevy1
67chevy1's Avatar
When you say all the clutch linkage. Do you need the clutch pedal, the piece that goes from the block to the frame, and the clutch rod that pushes on the throw out arm?
Old 12-27-2015, 08:05 PM   #20
rsmarr1982
rsmarr1982's Avatar
I need the rod that goes from pedal thru the firewall. The zbar I believe it's called the part between frame and engine. and the rod to clutch fork.
Old 12-27-2015, 08:09 PM   #21
67chevy1
67chevy1's Avatar
10 for the throttle rod , 70 for all the clutch parts, and 25 for the crossmember for a total of $105 and I'll get the shipping figured out tomorrow.
Old 12-27-2015, 08:20 PM   #22
rsmarr1982
rsmarr1982's Avatar
I will have to think about the clutch linkage I'd be buying it for spare. Definitely want crossmember.
Old 12-27-2015, 08:31 PM   #23
67chevy1
67chevy1's Avatar
Let me know. The shipping won't be anymore. It will all ship in 1 box and won't weigh enough to make a difference.
Old 12-28-2015, 05:58 PM   #24
67chevy1
67chevy1's Avatar
Shipping looks like it will be $28.00 via ups ground
Old 12-28-2015, 08:53 PM   #25
rsmarr1982
rsmarr1982's Avatar
Cool I will take it. I will have to pass on the other stuff due to a tight budget. What's your paypal?
