Old 08-18-2015, 04:33 PM   #1
$20071k10
$20071k10's Avatar
headers
What headers are you 4 speed guys running? can you run long tubes or are you stuck with shorty's
Brian
$20071k10 is offline   Reply With Quote
Old 08-18-2015, 04:41 PM   #2
snj8198
snj8198's Avatar
Re: headers
Hooker long tubes with full 3". Are you running a sb or bb?
Steve
1971 GMC Longbox. Full Roller Stroker 489 w/ FiTech EFI, Chris Straub Cam/NV4500/205/D60/14B w. Grizzly Locker and 4.11's. 2" Lift on 33's
snj8198 is offline   Reply With Quote
Old 08-18-2015, 06:52 PM   #3
b454rat
Re: headers
I ran chevelle headers on my big block 4wd. Hydro clutch need to moved but no big deal.
2000 GMC CCSB 454/4L80 6” lift SAS
1999 Chevy CCSB 454/NV4500 4” SAS
1999 GMC Yukon 350/4L60 6" SAS
Old 08-18-2015, 10:08 PM   #4
Re: headers
I always run full-length. You just have to look at the rear tube on the driver side and make sure it goes straight down or slightly forward. The only other possible issue is if they don't drop down enough to clear the lower arm on the bell-crank. I've had to cut that off and move over
Old 08-19-2015, 12:45 PM   #5
$20071k10
$20071k10's Avatar
Re: headers
I am running a sb you wouldn't happen to have a p# would you
Brian
Old 08-19-2015, 02:54 PM   #6
snj8198
snj8198's Avatar
Re: headers
I'm running a big block so i guess that doesn't help ya but I'm running these:
http://www.summitracing.com/parts/hok-2463-1hkr
Steve
Old 08-19-2015, 05:57 PM   #7
$20071k10
$20071k10's Avatar
Re: headers
thank you though
Brian
Old 08-20-2015, 01:31 PM   #8
$20071k10
$20071k10's Avatar
Re: headers
any one have p# for long tube headers that work good on a sbc with a 4 speed
Brian
Old 08-21-2015, 10:32 PM   #9
xbanone
xbanone's Avatar
Re: headers
Doug Thorley 364-y
1976 K15 Short/Step
1981 C10 short/wide
1994 K1500 ECSB
xbanone is offline   Reply With Quote
Old 08-25-2015, 08:50 AM   #10
Mike C
Mike C's Avatar
Re: headers
Heddman was the only header I could find that would work with the manual trans linkage when I put them on the Jimmy. I ditched them for 2 1/2" 'vette manifolds and could not be happier. My butt-o-meter shows about equal output on the top end with a little cam (Crane 266, 210 @ .050) and feels like it makes more low end torque. I went from 2 1/2" pipes on the headers to 2 1/2" on the manifolds which helped equalize the ouput I'm sure. Walker DynoMax Hemi Turbo mufflers were my choice. Nice sound with LOTS of sound deadening.
Old 08-25-2015, 11:53 PM   #11
RedRoad
RedRoad's Avatar
Re: headers
MikeC, did you use the dorman 2 1/2 ram horns? If so how are they holding up?
RedRoad is offline   Reply With Quote
Old 08-26-2015, 01:54 AM   #12
JIMs70GMC
user # 2756
JIMs70GMC's Avatar
Re: headers
I have the GM 2.5" ramhorns on my 70 GMC for 10+ years now, running strong.
1970 K25, 8' stepside bed 350/465/205 44 up front, 60 in the rear 4.10s rolling on 33" Dunlop MTs
1986 K5, 350/465/208 Dana 60/14 bolt from a cucv 36" Super Swampers TSL/SX
1983 K20 w/ CUCV axles, 350/700R4/208 sitting on 37" Goodyears
1986 M1031 6.2 diesel, TH400/NP205 locker in the rear and a LS in the front, all stock for now.....
1986 K30, 350/400/205 dana 60 and 14 bolt. I kept the drivetrain. Body/bad and chassis are gone.
1981 K30, 350/465/205 dana 60 and dually 14 bolt. Has a G80, and a flat bed. Going to replace the flat bed.
1985 K20, 350/400/208 10 bolt and SF 14 bolt. I wonder where I can find some 1 tons. Hmmmmm
JIMs70GMC is offline   Reply With Quote
Old 08-26-2015, 09:00 AM   #13
Mike C
Mike C's Avatar
Re: headers
I don't remember where I ordered them from but they are most likely the same as the Dormans. They've been on the truck 15 years now I bet. I bandsawed the generator mounts off and then painted them with Eastwood cast iron dressing if memory serves.
Old 08-26-2015, 11:34 AM   #14
RedRoad
RedRoad's Avatar
Re: headers
Thanks Jim and Mike, Im considering going with some Dormans but being that they are now made in China Im wondering how they would hold up in a heavy K20 suburban that will be towing a trailer.
Old 08-28-2015, 10:34 AM   #15
Mike C
Mike C's Avatar
Re: headers
I would think they would be fine. My manifolds came from Speedway motors if memory serves and they were not listed as Dormans. But most likely all are made in the same Chinese factory.
44 Willys MB
52 M38A1
64 Corvette Coupe
68 Camaro 'vert LT1 & TH700
69 Z/28 355 12.6's @110
72 Jimmy 4WD 4spd 4" & 35's
02 GMC 2500HD 4x4 Duramax
