Old 08-19-2015, 01:56 PM   #1
siggyfreud
siggyfreud's Avatar
Re: Building a Custom GMC Dash Bezel from the ground up :).
Are the tabs that hold the bezel in threaded, or is it supposed to fit via the taper wedging it in, and pins through the 4 tabs not letting it come out? If it was threaded it would be a lot easier, as the bolts could hold it in place, and the taper wouldn't have to be exact fit. Looks like I see nuts on them, so that might work . . .
I'm going to test fit tonight, and will try and do 2-sided milling to get some taper in there tomorrow or Friday.
siggyfreud is offline   Reply With Quote
Old 08-22-2015, 02:06 PM   #2
RKS0069
RKS0069's Avatar
The tabs are not threaded but do have j-nuts. I was envisioning pins holding in the top and you would reach under the dash to screw in the bottom.
http://67-72chevytrucks.com/vboard/s...d.php?t=675881
1972 C-10 SWB
1962 3/4 ton LWB
2011 GMC Sierra LML Z71 crewcab shortbed
RKS0069 is offline   Reply With Quote
