Flexplate cover bolts
Ok TH400 TCI streetfighter. .. I know this topic has been beat up but all the info I have found on bolts has not worked. Trying to bolt up my trans sheild, u all know thin metal sheild bottom of trans, 4 bolts..... WHAT are the bolt size and thread type... 1/4 inch/20 thread will not fit. Nor will 6mm... what u all got?
#2 | |
Re: Flexplate cover bolts
Tried those did not work
![]() Join Date: Sep 2007
it actually should be 1/4 -20
you might have to clean the threads. do you know what year your trans is?
1967custom |
Not sure year, I'll run a tap through them.
![]() Join Date: Mar 2003
Some of the old cases took a largish sheet metal screw with a 3/8 head on it
| Bookmarks |
