Door question
I am in the process of redoing interior work from a P.O. It's obvious that when I am ready for body and paint, I will need to spend time on the bottom of the doors.
Since I am redoing the door panels now, I was contemplating insulating the doors. Whats everyone's practice regarding this? do you use anything inside the doors? If so how do you address the water problem? Has anyone drilled extra weep holes?
FocuzTech Performance Evergreen Protective Coatings Gatorhyde...the best kept secret in spray in bed lining & protection |
I undercoated the inside of my doors with a couple good heavy coats. This will protect from water and offer some sound deadening as well.
I am a Referee of life.
Mike, I did drill a couple of extra weep holes.I probably wouldn't again because I have started to clear the originals each time I wash the truck and occassionally when it rains.I haven't had any water trapped in the doors since.
I have a 68 with metal door panels.I took the panels off and glued thin foam packaging wrap to the back.I also used a thin rubber impregnated gasket material to replace the original plastic sheet that helped keep the air from coming thru the window regulator holes and door handle holes.I replaced the eustacions ,too.(the little plastic rings behind the handles). This along with new window fuzzies and rubber helped quiten down the wind noise and the rattles.A sheet of dynomat would probably help but I haven't done it yet.The doors sound a lot more solid when I shut the doors now. Hope this helps.
The 47-present Chevrolet and GMC Truck Message Board Network,it's owners,moderators,members,and associates of any type should not be held responsible for my opinion. You can't fix stupid,not even with duct tape. "My appearance is due to the fact that "GOD" does punish you for having too much fun!" Barrett-Jackson has perfected alchemy,they make rust into gold! "You can lead a horse to water but you can't saddle a duck" "Cleverly disguised as a 'Responsible Adult' "Sometimes your Knight in shining armor is just a retard in tinfoil" |
its all about the +6 inches
PanelDeland, did yours actually have plastic under the door panel? All I have ever seen is paper.
