08-20-2015, 11:46 PM | #1 |
Measurement of Torsion Key Angle
08-21-2015, 09:36 AM | #2 |
Re: Measurement of Torsion Key Angle
You really don't need angle. Count the threads side to side should be close but could be off to level. If you are trying to clock key it's too much. How low? I had mine down to max without bump stops but was not worried about tires.
1962 shortbed 408cui small block, TKO 600 5-speed, bagged Porterbuilt suspension. 18" Salt Flats http://www.cardomain.com/ride/332579...t-c-k-pick-up/ http://67-72chevytrucks.com/vboard/s...d.php?t=560081 Last edited by LVPhotos; 08-21-2015 at 09:42 AM. |
08-21-2015, 11:43 AM | #3 |
But Found Her 25yrs Later!
In the pic posted by LVPhotos; see the gap between the torsion key and the torsion support crossmember?
I just made that gap the same. Then parked level, I measured from ground to top of front fender to ensure the drop was the same for both sides.
08-21-2015, 08:43 PM | #4 |
What i was trying to do was figure out what angle that the torsion keys sit at and then go out and make new torsion keys. With the hex part of the key at the slammed angle, but the key itself in the old (stock) position. So it, would allow the truck to sit slammed with the torsion keys all the way in the stock position. Thanks
08-21-2015, 09:12 PM | #5 |
Set the truck at new ride hight 60 is too much. 30 would give a good ride and camber 45 might work but no travel. Drop spindles and less key adjustment to keep alignment in check.
1962 shortbed 408cui small block, TKO 600 5-speed, bagged Porterbuilt suspension. 18" Salt Flats http://www.cardomain.com/ride/332579...t-c-k-pick-up/ http://67-72chevytrucks.com/vboard/s...d.php?t=560081 |
