Old 08-23-2015, 06:49 AM   #5
Dead Parrot
Re: Input on smog removal
From memory, my heavy duty emission 75 has the following vacuum items:
vacuum advance on distributor, PVC, brake booster, THERMAC(air cleaner), shift modulator on the transmission, and climate control(most of the flaps in your heat/air are vacuum powered). If you have and pull the charcoal canister you will need to arrange for gas tank venting(if it works, probably better off leaving it).
Dead Parrot is offline   Reply With Quote
