Old 08-24-2015, 07:53 AM   #1
lowlife21
Reverse lights
I converted an auto trans to a manual m21 4spd. I also have a new engine harness made for the manual trans my question is how do you wire the reverse light which is the light and dark green to the transmissions reverse light switch which I also have for the correct yr of the trans which is a red and light green wire. I'm guessing it's as simple has plugging the two end together but I just want to make sure.
lowlife21 is offline   Reply With Quote
Old 08-24-2015, 08:33 AM   #2
geezer#99
geezer#99's Avatar
Re: Reverse lights
Maybe not that simple!!
I assume you have a car type m21 with the shift levers on the side or are you talking about a truck 4 speed with the stock shifter in the top of the trannyy.
I've never seen an m21 with a back up light switch on it.
Old 08-24-2015, 08:51 AM   #3
lowlife21
Re: Reverse lights
It's a car tranny it's from a 69 corvette
Old 08-24-2015, 09:13 AM   #4
Jason Banks
Jason Banks's Avatar
Re: Reverse lights
If the switch has 2 connections. I'm pretty sure that dark green wire has 12v and the light green runs to the tail lights.
I would us a multimeter to see if the switch is 'open' when not in reverse, and 'closed' when in reverse. Then it is just as simple as connecting the two wires to the two connections.
On my 3speed On the Column there is a reverse switch on the column...so...your wiring might need extended.
Jason Banks is offline   Reply With Quote
Old 08-24-2015, 09:17 AM   #5
geezer#99
geezer#99's Avatar
Re: Reverse lights
The reverse switch was activated by a rod that connected the shift arm to the steering column. The reverse light switch was on the steering column.
Do you have a pic of this wiring and where you think you'll connect it on the tranny?
Old 08-24-2015, 09:35 AM   #6
lowlife21
Re: Reverse lights
Yes I have a rod connected to the reverse so the switch will then be activated when you throw it in reverse . The reverse Switch was on the column for the 3spd because that was shifter from the column but this is a car trans going in a truck so I do know that the switch was off the tranny I have that all installed I just now I have an open end wire ( not connected to the switch) one the engine harness itself I then have an open connection from the switch on the tranny that is also not wired to anything. I don't not have pictures right now I am away but I can get some later this afternoon
Old 08-24-2015, 09:36 AM   #7
lowlife21
Re: Reverse lights
Thank you jason I'll try that out when I get home
Old 08-24-2015, 09:39 AM   #8
geezer#99
geezer#99's Avatar
Re: Reverse lights
I'm just wondering about this 'switch' on the tranny.
If you're talking about the switch on the 3-4 shift arm, that's a ground switch.
Sorry if I've confused you!
Old 08-24-2015, 10:36 AM   #9
Jason Banks
Re: Reverse lights
Is this what the connector on the transmission looks like?
http://www.rockauto.com/catalog/more...nid=492&jpid=2
Or is it something on the shifter linkage?
Old 08-24-2015, 10:48 AM   #10
lowlife21
Re: Reverse lights
No how do you attach a picture on this site
Old 08-24-2015, 10:52 AM   #11
lowlife21
Re: Reverse lights
http://classicoldsmobile.com/forums/...utch-68-a.html
If you go to this site you'll see a tranny with the switch on it about half way down the forum
