Old 08-25-2015, 07:43 PM   #1
softballnrd27
Always a work in progress
softballnrd27's Avatar
New exhaust time
When I did my swap I did the exhaust with the intention of replacing it later on down the road. Well the time has come to start collecting parts for it. I'm tired of the flow masters that are currently on it. My plan is to eventually have headers but I'm gonna wait to find a good deal on some. I will have a tubular trans x-member so that I can tuck it up in the frame rails and an x-pipe after the trains with dynomax bullets with tailpipes coming out of the back some where. The only thing I can't decide on is size. Motor is 5.3 w/243 heads and a pretty healthy cam 224/230 .612/.600 112.5+2.5, 3600 stall converter and probably 3.70 or 3.90 gears. Is 3" too big?
USMC Retired
Never trust a man who can't laugh at his own fart!
2010 Silverado Crew Cab
73 SWB 5.3/4l80e
Build Thread:
http://67-72chevytrucks.com/vboard/s...d.php?t=695168
softballnrd27 is offline   Reply With Quote
Old 08-25-2015, 07:47 PM   #2
GASoline71
"I ain't nobody, dork."
GASoline71's Avatar
Re: New exhaust time
3" is what I would use...
Gary
'cuz chicks dig scars...
I would never rebuild a 305.
Old 08-26-2015, 08:32 AM   #3
Clyde65
Clyde65's Avatar
2.5" is plenty IMO. I have a 4.8 without the cam and run 2.25"
Clyde65
Rebuild of Clyde
http://67-72chevytrucks.com/vboard/s...84#post8338184
69 Aristocrat Lo Liner build
http://67-72chevytrucks.com/vboard/s...84#post7561684
support our troops!
Clyde65 is offline   Reply With Quote
Old 08-26-2015, 09:45 AM   #4
softballnrd27
1 3/4" or 1 7/8" header primaries?
Is there a header out there that somewhat fits 73-87 with dirty dingo slider mounts that doesn't cost $500+?
USMC Retired
73 SWB 5.3/4l80e
Build Thread:
Old 08-26-2015, 04:00 PM   #5
jackyl9999
jackyl9999's Avatar
I have 1-7/8 DT headers, Full length 3 inch duals. They dump right below the rear bumper. Mufflers are 12" dynomax bullets. It has a H-pipe near the rear of the transmission.
I love it.
1970 Gmc Grande Sierra Swb 2wd LSX (LQ4/4L80e)
1990 K1500 Daily
jackyl9999 is offline   Reply With Quote
Old 08-29-2015, 07:51 AM   #6
crazy longhorn
Fabricate till you "puke"
Agree.....even, with the cam, you don't need more on the pipe size 2 1/2" will hit you fine? Longhorn
69 longhorn,4" chop,3/5 drop, 1/2 ton suspension/disc brakes,1 1/2" body drop,steel tilt clip, 5.3/Edelbrock rpm intake/600 carb, Hooker streetrod shorties,2 1/2" exhaust/ H pipe/50's Flows , 6 spd Richmond trans,12 bolt/ 3.40 gears....
crazy longhorn is offline   Reply With Quote
