08-25-2015, 03:59 AM | #1 |
1965 c10 longbed wiper switch
hey guys i was wondering do you know if the stock wiper switch and motor are 2 speed or single speed ?
08-25-2015, 08:17 AM | #2 |
Re: 1965 c10 longbed wiper switch
Could be either. There were 3 option available.
-single speed -two speed -two speed w/washer option I'm not sure if the single speed could have been ordered with the wiper option. You will need the correct switch for which motor you have, but you can run a single speed motor on a two speed switch. (you would still only have 1 speed).
1963 Short bed step side SBW 427 big block and borg warner T-16 HD 3 speed manual http://67-72chevytrucks.com/vboard/s...d.php?t=519869 1963 Short bed fleetside BBW 348 1st gen big block w/Powerglide http://67-72chevytrucks.com/vboard/s...d.php?t=619024 1964 Short bed trailer Last edited by 1963c-10; 08-26-2015 at 09:24 AM. |
08-26-2015, 12:42 AM | #3 |
60-66 Nut
2 speed w/washer option?
08-26-2015, 09:23 AM | #4 |
Oops....yup.....washer option. Will correct it and thanks!!
1963 Short bed step side SBW 427 big block and borg warner T-16 HD 3 speed manual http://67-72chevytrucks.com/vboard/s...d.php?t=519869 1963 Short bed fleetside BBW 348 1st gen big block w/Powerglide http://67-72chevytrucks.com/vboard/s...d.php?t=619024 1964 Short bed trailer |
