Old 08-25-2015, 12:59 PM   #1
PGG
Need a new battery for my 72K5
What is the best truck battery I don't want the best warranty I want the one that most likely wont need the warranty.
What do you suggest cost no significant object.
Thanks PG
PGG is offline   Reply With Quote
Old 08-25-2015, 02:29 PM   #2
71jimmy
71jimmy's Avatar
Re: Need a new battery for my 72K5
If you want a stock appearing battery I don't know. I run an Optima Yellow top, which is a deep cycle bat. Mine sits for long periods of time. Have had it now for a couple of years and starts up every time.
'71 Jimmy, 350, SM465, NP205, 2in Tuff Country lift, 33s on rallies, TBI, softtop and hardtop
"If life was fair you'd be able to afford one of each and a garage large enough to house them all."
71jimmy is offline   Reply With Quote
Old 08-25-2015, 03:18 PM   #3
bamachem
bamachem's Avatar
I run 2 deep cycle marine batteries and use a marine battery switch to control the setup. I can have only Batt 1, only Batt 2, Both Batts 1 & 2, or totally off.
72 K5 Blazer - BCHWGN
bamachem is offline   Reply With Quote
Old 08-25-2015, 04:42 PM   #4
viking427
Odyssey and Deka are highly regarded.
www.odysseybattery.com/extreme_batteries.aspx
www.dekacatalog.com
Kinetic and XS are two more top, but lesser known brands.
Ive had more good luck than bad with Optima's, once I switched away from the red tops over to the yellow and blue tops.
viking427 is offline   Reply With Quote
Old 08-26-2015, 04:05 PM   #5
67 chevelle
67 chevelle's Avatar
I had an odessey in my chevelle , it cured some issues I was having , I highly recommend them
68 Long Fleet , ly6 , turbo 350 , 3-5 drop , original paint , front discs
67 Small window , 7 foot bed , tweaked 6.0 LSX 2004R Medium Olive
58 Apache fleet , 235 , offy intake , dual exhaust , 4 on the floor , red/white
69 Long Fleet , Custom , 6.0, 4l60 , AC , Medium Olive
67 chevelle is offline   Reply With Quote
