Old 08-26-2015, 02:03 PM   #1
kansasc10
kansasc10's Avatar
Should my vent window open in or out?
Ive searched pics and threads and cannot find my answer. When you open the vent window on your 72 c10, do you push the vent window out to open it, or do you pull it in? Right now, my vent windows push out which makes it so the window blocks any air from coming in the cab. Just want to make sure it was installed correctly.
kansasc10 is offline   Reply With Quote
Old 08-26-2015, 02:32 PM   #2
Shortie
Junior Member
Shortie's Avatar
Re: Should my vent window open in or out?
the back of the window should tilt out, i've always found that if i open them to the max (past 90 degrees) that the passenger side blows lots of air at drivers side and vice versa
Shortie is offline   Reply With Quote
Old 08-26-2015, 02:35 PM   #3
68 Stepper
That is correct, if you push it a little further it will direct air into the cab.
68 Stepper is offline   Reply With Quote
Old 08-26-2015, 04:19 PM   #4
kansasc10
kansasc10's Avatar
When you say the back are you referring to the part of the window closest to the door hinges? If thats the case, then mine is opening wrong. Mine opens with the back tilting in and all it does is block the wind. I get a lot more air in the cab leaving it closed. It seems like if it opened the other way, ie with the latch going in instead of out that the glass would direct more air into the cab. Mine opens like the picture....Is yours opening the opposite way? Thanks for the help btw...
Old 08-26-2015, 04:21 PM   #5
bigmac73
bigmac73's Avatar
that is the correct way as shown in the picture
Mike
72 C-10 Cheyenne off frame resto and Upgraded to 4 wheel disk, Tilt, Dakota Digital Dash / Rear slider.
421 SBC / TH350 3000RPM Stall
Progression Ignition /Holley 750 DP/3:73 gear Eaton Limited Slip unit / 2 1/2 exhaust glasspacks
bigmac73 is offline   Reply With Quote
Old 08-26-2015, 04:52 PM   #6
Lou Boffa
Lou Boffa's Avatar
full open, it will blow a lot of air into the cab. One of my favorite features of these old trucks.
Figure out what you want--then figure out what you are willing to give up to get it.
Lou Boffa is offline   Reply With Quote
Old 08-26-2015, 05:42 PM   #7
kansasc10
kansasc10's Avatar
Ok..then mine IS correct. Good to know thanks!
My mirror gets in the way when I try to fold it all the way out but thats an easy fix. I do wish it would open a little further than it does so I could direct more air at my face. I guess I better get my AC hooked back up.
I really appreciate the info guys!
Old 08-26-2015, 06:51 PM   #8
71CHEVYSHORTBED402
71CHEVYSHORTBED402's Avatar
It's a nice shot of air too, and that's before you open the vents, which I tend to forget is even there. Only downside of that is if you forget it's there, like I did, once opened you get blasted. Mine blew out all kinds of stuff, despite being garaged most of its life.
Tony
71 Custom Deluxe, SWB, 2WD, 402, A/C.
I developed an assembly guide (kit) for restoring this truck from the ground up, complete with details including full hardware descriptions. Much of the info. applies to all 67-72 GM. My build thread, with some info. about the assembly kit https://67-72chevytrucks.com/vboard/...d.php?t=730025
71CHEVYSHORTBED402 is offline   Reply With Quote
Old 08-26-2015, 07:12 PM   #9
jeffahart
jeffahart's Avatar
I agree. love wind wings. Hey, I noticed you have rifle racks! Same ones I had years ago. Love to keep levels in them. Not allowed to have them here. My nannies say.... NO!
White K20
jeffahart is offline   Reply With Quote
Old 08-26-2015, 08:20 PM   #10
nobolt
nobolt's Avatar
I was waiting for a punch line.... I guess I just got old.
Dave
"... government even in its best state is but a necessary evil. Thomas Paine
"It wasn't a lie, it was ineptitude with insufficient cover." Donald Draper (Mad Men)
nobolt is offline   Reply With Quote
Old 08-26-2015, 09:01 PM   #11
swamp rat
swamp rat's Avatar
I feel your pain..
Mike.
Swamp Rat build thread :
http://67-72chevytrucks.com/vboard/s...d.php?t=595019
72 3/4T 4X4
4" BDS Lift
33" BFG's
swamp rat is offline   Reply With Quote
Old 08-27-2015, 02:15 PM   #12
Lou Boffa
Lou Boffa's Avatar
Yup, that's what I call a mixed message!
Old 08-27-2015, 02:30 PM   #13
jeffahart
jeffahart's Avatar
Hahaha! But in Texas the deputies probably pull you over to mess with you over those stickers and not the rifle racks!
White K20
Old 08-27-2015, 02:45 PM   #14
Lou Boffa
Lou Boffa's Avatar
you got that right!
Old 08-27-2015, 11:49 PM   #15
cooperhw
cooperhw's Avatar
Sounds like ur air is hooked up..we used to call it 2-60 air conditioning. 2 windows à 60 miles per hour.
cooperhw is offline   Reply With Quote
