Old 08-25-2015, 12:37 PM   #1
jeffahart
jeffahart's Avatar
prying dash out to bolt up steering column
When I re-bolted up my steering column after re-installing my instrument cluster I had to pry the crap out of my dash to get the two front bolts on the plate( that holds the clutch and brake pedal bump stops) bolted up. It retracted about 3/8 inch. I could watch the instrument cluster plastic flex and I thought it was going to break.
Any tips on this. I need to pull the cluster again to do the volt meter and washer pump. Hoping to thwart the prying next time if possible.
Thanks!
White K20
jeffahart is offline   Reply With Quote
Old 08-25-2015, 04:03 PM   #2
moon
moon's Avatar
Re: prying dash out to bolt up steering column
Subscribed...
I have the exact same problem! Just dicovered it last night. I'm wondering what caused that section to move out of alignment that much with the truck just sitting there? The right side is easier to pry back up that the left side.
1970 CST long bed Fleetside
moon is offline   Reply With Quote
Old 08-25-2015, 06:42 PM   #3
leddzepp
Moderator
leddzepp's Avatar
Happens every time I remove/reinstall a dash. I use a screwdriver through the holes to pull it back in place, and then bolt it up.
1972 C/10 Cheyenne Super SWB. Restored, loaded, slammed.
1968 C/10 50th Anniversary LWB. Unrestored, stock, daily driver/work truck.
RIP ElJay
RIP 67ChevyRedneck
RIP Grumpy Old Man
Old 08-26-2015, 09:57 PM   #4
swamp rat
swamp rat's Avatar
If i remember correctly both bolts go in at an slight angle so i believe i had to push up on that bracket to get the bolts to start.
You can install the dash without removing that bracket, its a tight fit tho.
Mike.
Swamp Rat build thread :
http://67-72chevytrucks.com/vboard/s...d.php?t=595019
72 3/4T 4X4
4" BDS Lift
33" BFG's
swamp rat is offline   Reply With Quote
Old 08-26-2015, 10:08 PM   #5
69chevytrucker
69chevytrucker's Avatar
ya if you move the dash just right it will pop out and in a little scary but it will go i have been popping mine in and out as i work on the cluster
69chevytrucker is offline   Reply With Quote
