Old 02-12-2004, 11:37 AM   #1
2wdBlazer
The Blazer King
2wdBlazer's Avatar
Steering Shaft.
Anyone make an affordable shaft for lifted trucks? Mine doesn't look the best and has some slop in it. I saw some in summit but nothing for a 72.
72 2wd Blazer. Its the superbichinest, megacoolinest, superflowinest.
2wdBlazer is offline   Reply With Quote
Old 02-17-2004, 01:56 PM   #2
2wdBlazer
The Blazer King
2wdBlazer's Avatar
No Replies.
Everyone in a 67-72 still running a stock Shaft?
Old 02-17-2004, 03:25 PM   #3
6869704X4
You talking about the shaft between the column and the steering box? Going to cost you about $110. These are Coleman u-joints and a shaft I got from a racing shop. Cut the shaft to length and welded them together.
Coleman has a website too. Been awhile since Ive been on their site. Do search for Coleman Racing Products.
The more I learn about women, the more I love my truck.
6869704X4 is offline   Reply With Quote
Old 02-17-2004, 03:33 PM   #4
Mudder
Mudder's Avatar
I had 2 ujoints in mine at first but over time it started binding. Removed one and have had no problems since.
Mudder is offline   Reply With Quote
Old 02-17-2004, 03:54 PM   #5
6869704X4
So far, so good with mine. Two inch body lift. How much body lift do you have on your truck Mudder67? I'm sure that would affect it.
Old 02-17-2004, 04:11 PM   #6
Mudder
Mudder's Avatar
Quiet a bit in the front. My angle isnt that bad tho.
Old 02-17-2004, 05:04 PM   #7
2wdBlazer
The Blazer King
2wdBlazer's Avatar
That's what i'm looking for. Does anyone make a direct fit?
Old 02-17-2004, 09:38 PM   #8
2wdBlazer
The Blazer King
2wdBlazer's Avatar
I E-mailed Borgeson Corp. and here is the response.
We start with the '73 model year, but we can probably make a shaft that will work. Our typical truck assembly is a telescoping shaft with a needle bearing u-joint at each end, so we'd need to know the spline size at the steering column and steering box, and the approximate overall length. Cost would be $236.00, or $266.00 if you want to include a vibration reducer. Give us a call if you'd like to discuss this.
Anyone know the spline sizes or length?
