Old 08-26-2015, 09:33 PM   #1
hardwaycooke
hardwaycooke's Avatar
New through the fender exhaust!!!!
Front of rear tire. Sounds great!!
71 LWB
Large Bore 6-71 Blown 383 Stroker
4.11 Motive/EOM Eaton Posi Ported/Polished Carrier
15x8/15x16.5 MT Radials
B&M Pro Shifter
Truck Name- Spike
hardwaycooke is offline   Reply With Quote
Old 08-26-2015, 09:35 PM   #2
69chevytrucker
69chevytrucker's Avatar
Re: New through the fender exhaust!!!!
love it
69chevytrucker is offline   Reply With Quote
Old 08-26-2015, 09:50 PM   #3
trac209
Cool!
trac209 is offline   Reply With Quote
Old 08-26-2015, 09:56 PM   #4
1968aj
That looks good. How doyou keep it from rattling against housing?
1968aj is offline   Reply With Quote
Old 08-26-2015, 10:00 PM   #5
hardwaycooke
Its 2 pieces. Its a marine thru tip thats mounted to the fender. Then we added the 3" tips to run thru that and the tips are welded in place and cut for whatever look you want.. Might put some flex pipe later but now no need.
71 LWB
B&M Pro Shifter
Truck Name- Spike
Old 08-27-2015, 06:20 AM   #6
Andy4639
Old member
Andy4639's Avatar
Thumbs up Re: New through the fender exhaust!!!!
Looks good Dennis!
Seeing the USA in a 71
Upstate SC GM Truck Club
http://upstategmtrucks.com/
Old 08-27-2015, 06:33 AM   #7
yuccales
yuccales's Avatar
That looks real good.
yuccales is offline   Reply With Quote
Old 08-27-2015, 06:51 AM   #8
jessemthompson
Looks great.
jessemthompson is offline   Reply With Quote
Old 08-27-2015, 08:49 AM   #9
Fldawg
Fldawg's Avatar
looks good thats what i want to do to mine, except i want to do it at the back of rear tire . wonder if it will work
"Send in the clowns the goats are loose"
Fldawg is offline   Reply With Quote
Old 08-27-2015, 10:20 AM   #10
WarMonger
WarMonger's Avatar
Looks great. DO you have the link for where you got the marine tip?
..................... ____
.........________//__{\_____
,,,,,,,/__(O)___//___/__(O)_/
1970 C20
-_--_--_- ______
_--_--_- /___|__\____
-_--_-_ |_(0)|__|_(0)]
1972 K5
WarMonger is offline   Reply With Quote
