Old 08-27-2015, 01:45 PM   #1
Hicks
LS oil pan question
I have a 1970 CST-10. I will be installing a 2011 LS 5.3 from a 4x4 1500 pickup. Will the stock oil pan work or should I get an aftermarket pan such as the Holley unit? I want the engine in the stock location if possible. Also who makes the best fitting motor mounts and headers? Thanks, Randy
Hicks is offline   Reply With Quote
Old 08-27-2015, 02:05 PM   #2
Taibo
Re: LS oil pan question
The engine will come with the pan so, try it and see if it fits. The Holley pan should work and so will the MAST performance pan. They are rear sump and both should fit but they are too pricey (~3-500) to buy ahead of time only to find you just don't need it. As for headers, I use Sandersons but, as you will soon discover, opinions on headers are like noses; everyone has one and they are all different.
Taibo is offline   Reply With Quote
Old 08-27-2015, 03:19 PM   #3
67 chevelle
67 chevelle's Avatar
I used gm musclecar pans on mine . gives you a couple inches clearance over stock truck pan , a holley pan is expensive and not needed
68 Long Fleet , ly6 , turbo 350 , 3-5 drop , original paint , front discs
67 Small window , 7 foot bed , tweaked 6.0 LSX 2004R Medium Olive
58 Apache fleet , 235 , offy intake , dual exhaust , 4 on the floor , red/white
69 Long Fleet , Custom , 6.0, 4l60 , AC , Medium Olive
67 chevelle is offline   Reply With Quote
Old 08-27-2015, 03:37 PM   #4
Aruba1
Depends on which position you use to accomodate the LSX motor. On mine I opted for the LSX to fit in the stock SBC location. The stock oil pan fits nicely with probably 2-3" clearance but my truck a 2WD (1972). The headers (no name brand) fitted like a glove, no clearance issues whatsever. I got my motor brackets off ebay and it was the non-adjustable kind. One issue I ran into is that one of the bolts on each side had to be grinded about 1/8" as it was bottoming down on the block. There's always something when you doing conversions :-).
Aruba1 is offline   Reply With Quote
Old 08-27-2015, 04:00 PM   #5
cooperhw
cooperhw's Avatar
Might check out the "Dirty Dingo" motor mounts. They are adjustable. Wish I would have had them when I put mine in my Chevelle.
"Life is too short to drive a boring vehicle".
Later,
Wayne
cooperhw is offline   Reply With Quote
Old 08-27-2015, 07:39 PM   #6
bpatrol
using the stock truck pan or even the muscle pan is fine but these are deep pans and may hang below the crossmember , so it will be exposed to a direct hit if you run over something. As suggested use the holley pan or mast pan. you might even be able to use a f body pan also.
good luck either way
bpatrol
bpatrol is offline   Reply With Quote
Old 08-27-2015, 08:54 PM   #7
aod92
aod92's Avatar
I have a gm muscle car pan on mine and it's about even with the crossmember.
aod92 is offline   Reply With Quote
Old 08-27-2015, 09:08 PM   #8
Hicks
Thanks guys for all the info, I'm trying to learn as much as possible before I start this project. This will be my first LS swap. Any other advice you might have would be greatly appreciated. Randy
Old 08-27-2015, 10:47 PM   #9
lutronjim
Check
http://www.brphotrods.com/mm5/mercha...gory_Code=CNV9
lutronjim is offline   Reply With Quote
Old 08-27-2015, 11:12 PM   #10
fast&low
X2 On the GM Musclecar oil pan fits even with the frame and I highly recommend Dirty Dingo slider plates.
fast&low is offline   Reply With Quote
Old 08-28-2015, 07:44 AM   #11
Matt Cramer
I used the stock truck pan with the engine in the stock location relative to the transmission. It's a little lower than the crossmember, but clears everything nicely.
I used homemade adapter plates (if I were to do it over again, I'd also put in the '73-up engine stands for more clearance) and 2010 Camaro exhaust manifolds.
Matt Cramer
1972 Chevy C10 - 4.8 swap, long bed, and maybe one dent free body panel somewhere - SOLD
4.8 LS build thread
Matt Cramer is offline   Reply With Quote
Old 08-28-2015, 08:02 AM   #12
67 chevelle
If you plan to c notch the rear frame and lower the front 5 inches , [lay frame truck] ,you should get the holley pan[about $400] , If you are planing a 3-5 or 4-6 drop truck the musclecar pan from gm [about $200] is recommended , stock truck , stock truck pan is fine , but will hang below front crossmember about 2 inches .
lots of info here http://67-72chevytrucks.com/vboard/f...play.php?f=206
