Old 08-27-2015, 07:00 PM   #1
71CHEVYSHORTBED402
71CHEVYSHORTBED402's Avatar
12-bolt differential cover, black color and texture?
This is a picture of my OE differential. I hit it twice with naval jelly. There's still some rust. I haven't used any sandpaper or a wire-brush yet, because I'm not certain of the correct surface. Unless ill-advised, I'll probably soak it in white vinegar overnight.
I hit it twice with aircraft paint remover, then some Jayco garbage. Whatever it is, the black doesn't budge. Could this be it's because a rust converter was used?
Also, the face of it is textured, and the one on my truck is the same. Is the texture original?
Funny, there appears to a dent or two in the center on this pic. I need to take a peak. Edit: Yep. I managed the edges, but I'll hire this out. Not that it's obvious. First time I noticed.
Tony 1971 C10 Custom Deluxe SWB 402/400TH A/C
I developed an assembly information kit for restoring my truck from nuts and bolts. It's written in Assy. order, short & simple, packed with all OEM hardware ID; castings; part ID; 100s of part numbers; wiring simple - Resource, and trivial too.
Much info. applies to all 67-72 GM, A/C vehicles, esp. trucks W/O saying. Full search ability, including to 700+ images of illus., parts, charts, Assy., points of interest, cab, bed, & front clip cart plans- Specials and cores were serviced out and R excluded e.g. front/rear glass, body/paint, engine core, rebuilt hinges, steering box, trans, etc.
The project was in-line with long former professions developing process, policy, specs, demo, written for novices, admin., policy, engineers, development, systems & test - Public & govt 2, gross. Sell soft copy cheaply, PM if interested.
Build thread:https://67-72chevytrucks.com/vboard/...d.php?t=730025
71CHEVYSHORTBED402 is offline   Reply With Quote
Old 08-27-2015, 07:24 PM   #2
jocko
jocko's Avatar
Re: 12-bolt differential cover, black color and texture?
to be honest, the texture looks as though it were rusted enough to profile the metal. Black, although I can't really tell where it is, is possibly rust converter, but if all you've done won't clean it off, I wouldn't worry about it peeling under your paint. Just sand it well. I've not seen a diff cover with texture, but that does look a lot like stuff I've had that sat outside for years and rusted - and it still looked this way after I cleaned it. Having said that, the part is perfectly good, but it may not provide the show-smooth finish you seek, if you seek one. I'd clean it thoroughly (you have), sand it some to see if you can affect that texture, and then slap it with converter (spray) and prime and paint it. It will be fine. Or, a new or other replacement without the texture should be able to be had rather cheaply. If you want it smooth, that's probably what you'll need to do. But it will work fine as is.
Old 08-27-2015, 07:34 PM   #3
bpatrol
perhaps its powder coated?
you can get a textured finish with powder coating and it is difficult to remove. just sand it smooth and you should be okay
god bless
bpatrol
bpatrol is offline   Reply With Quote
Old 08-27-2015, 07:35 PM   #4
71CHEVYSHORTBED402
I'm not sure what metal profiling is. If you look online, you'll see all of these OE's have texture. I haven't seen an NOS, which would probably explain a lot. Take a look: http://www.google.com/custom?domains...D%3A1%3B&hl=en
Old 08-27-2015, 07:48 PM   #5
71CHEVYSHORTBED402
god bless
bpatrol
Aircraft Remover removes powder coating easily.
Old 09-05-2015, 12:31 PM   #6
71CHEVYSHORTBED402
Well, I got it down to metal. Heck with naval jelly, white vinegar is your friend.
This was a real beatch. I believe there was some type of rust converter, but it only effected the surface, as there was lots of rust. There are a few flaws on the flat surface, but I think it's better I not sand any further down. Got a little carried away with the wire wheel (black area, lower LH side). May smooth things out a bit with primer, while maintaining some texture on the face. Anyway, this is approx. what they look like new.
Old 09-05-2015, 12:40 PM   #7
vics stuff
Your cover has been exposed to serious moisture over the years
Vic
vics stuff is offline   Reply With Quote
Old 09-05-2015, 12:42 PM   #8
indymachinist
That is rust pitting. I don't believe they look like that new.
It is still a perfectly useable part.
-Curt
My 1968 Chevy shortbed stepside build
indymachinist is offline   Reply With Quote
Old 09-05-2015, 12:44 PM   #9
71CHEVYSHORTBED402
There is some pitting. I could be off the mark here, but am fairly certain the faces on these are textured, similar the differentials themselves. The original on my truck is the "same" and it's been garaged in a dry climate. Shame the edge on it was jacked up ......Literally. It's possible they had a tendency to pit regardless.
Old 09-05-2015, 01:11 PM   #10
71CHEVYSHORTBED402
Anyone have an original 12-bolt cover? Smooth or textured? Incidentally, the outer edge around the face on these are smooth. Don't know why it wouldn't be "pitted" as well.
Old 09-05-2015, 02:06 PM   #11
Bigdav160
Bigdav160's Avatar
I've bought a new cover from the dealer years ago. It was smooth and unpainted. I think the factory might have sprayed some type of undercoating. I've seen the same texture on mine.
My Classics:
'72 K20 Suburban + '65 Dodge Town Wagon
'72 Corvette Roadster +'67 Corvette Roadster
'73 Z-28 Camaro
'63 Ford SWB Uni Pickup
'50 Ford Coupe
Bigdav160 is offline   Reply With Quote
Old 09-05-2015, 02:26 PM   #12
GASoline71
"I ain't nobody, dork."
GASoline71's Avatar
Factory they are smooth. But road salt and water usually pit the hell out of them.
Gary
'cuz chicks dig scars...
I would never rebuild a 305.
Old 09-05-2015, 03:55 PM   #13
indymachinist
That texture is absolutely from rust pitting. That cover would have been smooth when new from the factory.
-Curt
Old 09-05-2015, 06:08 PM   #14
RustyBucket
RustyBucket's Avatar
O'reilly will sell you a Spectre chinese chrome one for $18. Scuff it up with wet or dry paper and spray it with Krylon 1613. don't tell anybody.
your rear end(cover) will be smooth as a baby's...
Dad always said, "Son, WISH IN ONE HAND, and ......."
Current toy trucks:
'71 GMC 1500 SUPER CUSTOM short/step, orig. dk. blue, 350/700r, ps,pb, A/C
'72 Blazer 2wd, ochre & white, 454, tremecTKO 500 5spd. ps, pb, A/C, tilt
Last 10yrs of hobby vehicles, had a FEW more in the 50yrs. before these:
'66 Plymouth Belvedere City of Miami cop car clone.
'70 Nova 406"sb, 13.5-1, solid roller, Brodix, p.glide/t.brake, back halved, 9" Ford, spool 4.88, cage,ladder bar/coilover, 10.5 tire....... SOLD!!
'67 C10 short/step side mount spare -- SOLD!!
'72 Jimmy 2wd, 350/350, ps, pb, fun driver, lots of bondo & a shiny red paint job..... SOLD!!
'69 Nova 350, 4spd, A/C, ps, p.b, ...SOLD!!
RustyBucket is offline   Reply With Quote
Old 09-05-2015, 06:34 PM   #15
leddzepp
Moderator
leddzepp's Avatar
I did this too. Remember to scuff the chrome mounting surface, and it won't leak.
1972 C/10 Cheyenne Super SWB. Restored, loaded, slammed.
1968 C/10 50th Anniversary LWB. Unrestored, stock, daily driver/work truck.
RIP ElJay
RIP 67ChevyRedneck
RIP Grumpy Old Man
RIP FleetsidePaul
Old 09-05-2015, 09:31 PM   #16
71CHEVYSHORTBED402
Pretty sure you said I've got lots of sanding to do. That or buy an aftermarket. CRaaaaaaaaaaP!
Old 09-06-2015, 05:12 PM   #17
young grasshoppa
young grasshoppa's Avatar
can you even buy plain black covers these days? I only see the chrome ones for sale...
young grasshoppa is offline   Reply With Quote
Old 09-08-2015, 10:39 PM   #18
71CHEVYSHORTBED402
Only one I see in the same shape is chrome.
You guys were dead-on about the pitting. Course you knew that. It was pretty bad.
I had dedicated too many hours already, so I dedicated more. I've never done "precise" metal work before, but I hammered out the dents, which were all small (lucky). Shaped it right. Sanded, sanded and sanded. Kind of cool making it like new again. At any rate, I got most of the pitting out and it's flat. A couple layers of epoxy, it will be smooth too.
Was it worth the 8 hours plus scrubbing and sanding? Before I hammered the dents out I thought no (did it out of frustration with pitting, figured what the heck). Besides, I learned something. Thanks for your help.
