The Older Generation
Re: Why does my clutch linkage keep breaking?
Also check the clutch fork and make sure it isn't hitting the bell housing when the clutch pedal is depressed. If it is, only a couple of things can cause this, either the ball stud inside the bell housing is broken off or missing, or the throwout bearing is too short. I have seen clutch forks worn bad enough that the ball stud had worn through the clutch fork socket also. LockDoc
