Old 08-28-2015, 04:09 PM   #1
ADchevys
King pin removal
Trying to remove king pins on a 53 Chevy axle. I got both lock pins out and the dust caps off, shouldn't they press out?
ADchevys is offline   Reply With Quote
Old 08-28-2015, 04:54 PM   #2
mr48chev
mr48chev's Avatar
Re: King pin removal
BIG hammer and a drift just a tad smaller than the king pin. Have the axle supported solidly close to the end.
Usually once you get them started moving you can drive them out.
I have had them pressed out with a big hydraulic press before though.
I was thinking about using my balljoint press to push the ones out on the two axles I have out here that I need the king pins out of but haven't got around to it yet. That is kind of like a big super heavy duty C clamp setup.
My ongoing truck projects:
Old 08-28-2015, 07:36 PM   #3
1project2many
Yep... ball joint press should do it.
I have a king pin tool at work for larger trucks. It wouldn't fit the '57 so I used my ball joint press. I actually torqued the push bolt until the "C" of the press just started to bow then struck the head of the bolt with a medium shop hammer to get the pin to begin moving. After the pin was nearly out I ended up using the cutoff wheel to remove any trace of mushroom from the end of the pin.
1project2many is online now   Reply With Quote
Old 08-28-2015, 08:05 PM   #4
1-ton of fun
polishing a turd
1-ton of fun's Avatar
We ended up buying a 20-ton shop press from harbor freight and it pressed them right out for us. It was useful for pressing out the bushings too
1-ton of fun is offline   Reply With Quote
Old 08-28-2015, 08:37 PM   #5
ADchevys
Got them out with a big hammer. Thanks for the help.
Old 08-30-2015, 09:34 AM   #6
57chevyman
57chevyman's Avatar
i had a king pin so frozen on my 1992 international 4700 truck . the mechanic had to heat it with a torch in addition to using the press and whatever tools they were using
Frank
1957 Chevy 3100
2000 Silverado z71 SOLD
2012 Ram 1500 Quad Cab
1992 International 4700
57chevyman is offline   Reply With Quote
Old 08-30-2015, 12:28 PM   #7
mr48chev
mr48chev's Avatar
I haven't checked but you can probably "borrow" a ball joint press at Autozone. Just make sure that the pin on the press is smaller than the king pin and watch getting the threads caught up in the bushing.
I've got two axles out here that I need to take the spindles off so I can try it.
Old 08-30-2015, 01:46 PM   #8
dwcsr
Hollister Road Co.
dwcsr's Avatar
Most time the pin is frozen and needs heat and a press. You could spend 10 hours beating on a pin to save $50 in press work. We use a pin press like this one
http://public.snapon.com/R_RRD/Objec...ges/CG230A.jpg
I'd take the axle to the machine shop that's fitting the pins and have them press them out and check to see if you need over size pins.
Old 08-30-2015, 04:11 PM   #9
mr48chev
mr48chev's Avatar
You could wag the axle down to the machine shop and have the king pins pressed out a lot of times for the price of that tool. 495.00 puts it out of reach for most home hobby guys who may only do a set of king pins every three or four years if that. This is where it is more prudent $$ wise to just go have someone do the job you need done.
Old 08-30-2015, 04:34 PM   #10
xaircav
xaircav's Avatar
Now that they are out consider Stainless Steel Brakes needle bearing king pins. Pricey but they can be installed without a press.
xaircav is offline   Reply With Quote
Old 08-30-2015, 05:01 PM   #11
mr48chev
mr48chev's Avatar
Nice if they fit in your budget. I'd make sure that I kept them well greased though.
Old 08-30-2015, 06:37 PM   #12
ADchevys
I plan on sending the axle down to Sid and have it dropped 4 inches. I am going to have him Install the spindles.
Old 09-03-2015, 02:58 AM   #13
tmoble
I went to SSBC, they only had pin kits for early fords and an Olds? Spendy stuff. They can have it, For that money I could replace a lot of kingpin bushings. Don't see any way for grease to get to the Torrington-type bearings that support the weight.
tmoble is offline   Reply With Quote
