1996 454 tbi in 87 GMC. Easy swap??
Thanks to this thread I had to buy another truck because I fell in love with his truck and being a stepside. You just dont see step sides around here anymore. http://www.gm***************/forum/sh...ght=circuitguy
To make a long story short, I ended up with a long bed fleetside. 87 GMC sierra TBI. Im going to shorten the frame for a shortbed and am in on the hunt for a stepside bed. I have a forum member here helping me out on a bed. The truck has a tired but good 350 TBI with 700R4. Everything I got planned for the truck will take some time to plan. My question is, How hard would it be to swap in a 96 454 TBI into my 87. I have the complete donor truck. 96 suburban 2500. Runs excellent. I know they get real bad gas mileage, but in a lighter truck with the tbi and true dual exhaust everything else stock, should make for a fun truck to drive. Anyone done this swap?? |
Re: 1996 454 tbi in 87 GMC. Easy swap??
I can't personally say how difficult it would be, but I see the transfer case being an issue. Later Chevy's used independent front suspension and switched to driver side drop on the transfer case. Those 87's are passenger side drop. Also, I saw somewhere that 3/4 ton trucks used more splines on the transfer case than the 1/2 ton.
The wiring should be relatively straight forward. You are going to need most of the suburbans wiring. Never dealt with the big block stuff, so I don't know how the engine will sit in there. I'm guessing at a minimum you will need a new engine cross member and possibly a transmission cross member. Keep us posted on this! I have an 89 with a motor that will need rebuilding soon. Debating on whether to swap or rebuild.
1972 GMC Jimmy Custom 4.8L (L20)/6L90E/NP205 1989 Chevy Suburban V2500 350/Turbo 400/4.11 gears 1996 Chevy Suburban K1500 350/4L60E |
1996 454 is not tbi. It's a vortec engine with mulitport injection. So if it is tbi, its 95 and older. The wiring isn't terribly bad, and just have the ecu tuned by a company to delete all the extra crap not needed. If it is a TBI, you need the ecu flashed. Vortec can be tuned with a program. I have my 97 tuned with out smog and all the extra crap that gm puts in their computers
Project Roxy... Shes Bad, Low, and Blown... http://67-72chevytrucks.com/vboard/s...d.php?t=673333 |
#4 | |
As for the physical swap part of it, get a set of big block towers and its a bolt in deal. The blocks didn't change as they got newer. If the 454 has a 400 behind it stock, its definitely an older tbi engine.
Posted via Mobile Device |
#6 | |
If your ultimate plan is ls, then save your money and keep your SBC..
I second that. No sense wasting time and money if your current setup works and will hold out until you get what you really want.
Yeah if your truck runs and drives now i would wait and go ls.
| Bookmarks |
