Old 08-28-2015, 08:05 PM   #1
msg
Rim restoration and hubcap questions
I have been breaking down my truck and having parts sandblasted and thought the rims might need the blast but after taking them off I dont know, they arent all rusted like I thought they might be.
So I have 2 questions
  1. To match the body color like I want, should I only have the front and back blasted and repaint them?
  2. I wanted to go with hubcaps like these in this post but how can you measure to tell if they will fit my rims?
http://67-72chevytrucks.com/vboard/s...71#post7290971
Here is a pic of the rims, the tires that came off measure P235/75/R15
Progress thread for my 66
http://67-72chevytrucks.com/vboard/s...d.php?t=623848
msg is offline   Reply With Quote
Old 08-28-2015, 08:53 PM   #2
chiefcfd
chiefcfd's Avatar
Re: Rim restoration and hubcap questions
Those hubcaps will not fit the rally wheels you have. The center for rally wheels use bolts to hold them on. The hubcaps need the nubs on the center of the wheel to snap onto. You would need a regular steel wheel. You could post those up for sale somewhere and get a good set of steel wheels and have them powder coated.
1972 Chevy LWB Roadster
1999 Chevy Silverado 2wd
2015 Chevy High Country 4x4 Crew Cab
chiefcfd is offline   Reply With Quote
Old 08-28-2015, 08:57 PM   #3
firedemon
I think those rims look great body color with the trim rings and stock center caps
firedemon is offline   Reply With Quote
Old 08-28-2015, 11:21 PM   #4
msg
Thats exactly what I had going on,
I always liked what was more stock like this
But the dog dish caps for a 66 are not cheap and Ive seen that 75 style painted white with red center and for a temporary I thought I might try that. But sounds like neither will work on these rims I have. Thanks for the help guys.
Old 08-29-2015, 09:49 AM   #5
Already Gone
70+ ( Old Skool Club )
Already Gone's Avatar
I understand what you want to do. Those rallys you show are 15 x 8 inches wide and trying to find steel rims that are 15 x 8 with 6 holes is tough and usually they are expensive when you find them. You could always use the stock 15 x 5.5 or 6.5 steel rims that were on the 67-70 trucks and they have the nibs for the small hubcaps. It looks like you would have to get smaller tires as well if you went with the 5.5 or 6.5's.
1992 K1500 GMC Suburban
" Circumsatances Do Not Change Responsibility "
" The Sky is not the Limit, Your Mind is." Marilyn Monroe ..
RIP Charlie Watts 1941 - 2021
