Closed Thread
Old 08-30-2015, 11:40 AM   #1501
scuderia
scuderia's Avatar
Re: What did you do to your truck today part III
Ordered a new Fuel Pump! Since putting in my 292 (used CL) it's had a pretty good tick. The motor starts and runs fine, good even. Doesn't smoke or seem to burn oil. Does have a couple of good oil leaks (oil pan and maybe rear seal) but this tick has been really bugging me. I've been reluctant to deal with the oil leaks only to have the thing grenade on me... Anyway, I've adjusted the valves a couple times and tightened the exhaust etc. but nothing made a difference.
So yesterday I was changing some grommets on the valve cover (one leak I figured I could at least address) and I fired it up and for whatever reason it I could suddenly tell the tick wasn't coming from up top. I grabbed a long screwdriver and sure enough the only place you can hear the tick is from the damn fuel pump!! Won't know for sure till I get the new one in but fingers crossed.
'66 C10 SWB
'64 C2 roadster
'38 Indian Scout Flattracker
'70 Triumph T120R
'81 Laverda Jota
scuderia is offline
Old 08-30-2015, 02:04 PM   #1502
Lugnutz65
Lugnutz65's Avatar
Originally Posted by LT1 Burb View Post
I installed my exhaust system, fixed a leaking diff gasket, bled my master and installed it, installed my radio, air box, and speaker and started finishing up some small things that needed completion.
LT1 Burb,
Truck looks great! Really great! Please tell me about the hole(s) you have cut in the firewall on the PS. I assume they are for AC since I see a compressor and AC vents. How did you decide where to cut holes and what will you install? Vintage Air?
My 65 C10 build: www.lugnutz65chevystepside.weebly.com
Want to know more about T5 transmissions? My website has a T5 Info Page and a Step by Step T5 rebuild.
Lugnutz65 is offline
Old 08-30-2015, 07:25 PM   #1503
TJ's Chevy
TJ's Chevy's Avatar
Got the front hubs and wheels on. Then rolled the chassis out for some fresh air.
TJ's Chevy is offline
Old 08-30-2015, 08:10 PM   #1504
Classic v6 GMC's
Classic v6 GMC's's Avatar
Originally Posted by TJ's Chevy View Post
I got my engine and tranny mounted!
Looking good!!
Classic v6 GMC's is offline
Old 08-30-2015, 08:43 PM   #1505
LT1 Burb
LT1 Burb's Avatar
Originally Posted by Lugnutz65 View Post
LT1 Burb,
THx, Its a factory Air cab, going back with OEM stuff.
LT1 Burb is offline
Old 08-30-2015, 09:04 PM   #1506
TJ's Chevy
TJ's Chevy's Avatar
Originally Posted by Classic v6 GMC's View Post
Looking good!!
Thanks! Feels good to! lol
Old 08-30-2015, 09:21 PM   #1507
revjames
Finally got the hubs and calipers on I am suppose to get my parking brake in the mail tomorrow from inline. That's all that stands between me and a roller.
revjames is offline
Old 08-30-2015, 10:37 PM   #1508
Chevy Fleetside
Chevy Fleetside's Avatar
I didn't work on my truck today but I did work on my brothers car. I am putting disc brakes in his 64 Valiant. I am using discs from a 75 Duster. As I was changing the wheel bearings I notice this on the left rotor. I guess he took his car to Midas to have the brakes done. Someone put the seals in backwards.
"A man and his truck, what a beautiful thing"
65 Short Fleetside BBC
65 Long Fleetside 283 3 on the tree for now.
my build thread http://www.67-72chevytrucks.com/vboa...d.php?t=259536
Chevy Fleetside is offline
Old 08-30-2015, 11:15 PM   #1509
jbgroby
jbgroby's Avatar
Got a call from the painter who wanted to go over the paint colors and have them verified before spraying. If all goes well the bed should be finished by Sept 12.
jbgroby is offline
Old 08-30-2015, 11:26 PM   #1510
markeb01
Senior Enthusiast
markeb01's Avatar
Wow! Won't that be a sweet thing after all these years.
My Build Thread: http://67-72chevytrucks.com/vboard/s...d.php?t=444502
markeb01 is offline
Old 08-31-2015, 10:13 AM   #1511
jbgroby
jbgroby's Avatar
Yes it will be!!!, note the extra holes that the PO drill in the tail light area instead of getting some speed nuts. does not hurt anything, but WHY?? The painter also undercoated the insides of the bed as well. The sides are finally straight as well.
jbgroby is offline
Old 08-31-2015, 10:40 AM   #1512
The Rocknrod
Moderator
The Rocknrod's Avatar
Whats that little tab hanging off your upper ball joint? Where did you get it?
The Rocknrod is offline
Old 08-31-2015, 11:15 AM   #1513
Grizz1963
Grizz1963's Avatar
I was going to find some procrastination project to do, then realised the inner fenders will never clean themselves.
Both sides are now ready for paint prep, primer coat followed by Satin Black Two Pack paint.
Today after the inner fenders I finished reassembly of the heater unit and packed it away.
The lid is away with Ian Brown for some special under hood treatment.
The red you can see is a high density foam gasket I made to seal the fan to the metal case.
MY BUILD LINK: http://67-72chevytrucks.com/vboard/s...585901]Redneck Express - 1966 C10 Short Fleetside
MY USA ROADTRIPS http://forum.retro-rides.org/thread/...2018-humdinger
IF YOU CAN'T FIX IT WITH A HAMMER, YOU'VE GOT AN ELECTRICAL PROBLEM MATE.
Grizz1963 is offline
Old 08-31-2015, 02:37 PM   #1514
Eagletucky
Where did THAT bolt go?
Eagletucky's Avatar
I finished up shortening my '66 Suburban 3", in preparation for a body swap on a 2006 Trailblazer SS. I also removed the stock burb floor in one piece:
The Swiss Car Club......A drinking club with a car problem....
Eagletucky is offline
Old 08-31-2015, 02:47 PM   #1515
LT1 Burb
LT1 Burb's Avatar
Thats gonna be wild, brave guy!
LT1 Burb is offline
Old 08-31-2015, 07:02 PM   #1516
Turtleman
Turtleman's Avatar
I hope you start a build topic for that,, I'm guessing theres ALLOT of people here that would be interested in how all that fits together
Turtleman is offline
Old 09-01-2015, 02:06 AM   #1517
Grizz1963
Grizz1963's Avatar
That should be very good.
I am not that clever or brave.
Build thread please, or some thread for us to ooooohhh and aaaahhhh and be amazed by.
Old 09-01-2015, 11:48 AM   #1518
BenkeBird
BenkeBird's Avatar
I have weld some sheetmetal on my -62 panel this last week.
BenkeBird is offline
Old 09-01-2015, 03:01 PM   #1519
Northwest Outlaw
Northwest Outlaw's Avatar
Not necessarily "today" but most recently (took me a week) I rebuilt the Rochester BV carburetor on my mystery year 250 i6.
Used a rebuild kit from Mike's Carburetors (www.carburetor-parts.com/) but had to order some extra bowl gaskets to overcome the warped parts!
Also took a wire brush on the grinder and cleaned off the rust and old paint from the air cleaner. I really like the "polished patina" look when it was done so I hit it with a glossy clear coat. Thinking i'll do the valve cover and push rod covers the same.
Not big steps I know, but she's running and driving again and pretty smooth too!
1961 Chevy Apache "BoomStick"
-First build, lots of plans, little experience. What's the worst that could happen?
http://67-72chevytrucks.com/vboard/s...d.php?t=694506
Northwest Outlaw is offline
Old 09-01-2015, 08:28 PM   #1520
65Gregg
65Gregg's Avatar
In wanted holes in the firewall are patched and the floors covered with POR-15, tomorrow I'll start with the Rattletrap. Slow but at least it's progress
65Gregg
Blue long bed
White TBSS
61 Impala
“The two most important days in your life are the day you are born and the day you find out why.” Mark Twain
65Gregg is offline
Old 09-01-2015, 09:07 PM   #1521
That looks very nice!
Palf70Step is offline
Old 09-03-2015, 12:29 AM   #1522
65Gregg
65Gregg's Avatar
Thank you, it's almost all covered with insulation now.
65Gregg
Blue long bed
White TBSS
61 Impala
65Gregg is offline
Old 09-03-2015, 04:44 PM   #1523
Grizz1963
Grizz1963's Avatar
Ordered my full set of mouldings and stainless bed strips from Mar-K today through Clem's Tuba Trucks.
Thanks Clem.
Got home tonight and found this had arrived in the post from Ian Brown.
I already reported on this cover, but have to say, in hand, it is even more impressive.
I am seriously pleased and impressed with it. It is so difficult to capture the texture and look of this piece in a photo.
Of course I had to go trial fit it as well.
Very pleased, very very pleased.
Old 09-03-2015, 06:54 PM   #1524
pimpston65
pimpston65's Avatar
what are you gonna use as the floor?
pimpston65 is offline
Old 09-03-2015, 09:42 PM   #1525
Eagletucky
Eagletucky's Avatar
Ill post more pics in a build thread in the near future.
Im using the floor and firewall out of the Trailblazer SS.
Closed Thread
