Old 07-29-2015, 10:03 AM   #676
Advanced Design
Advanced Design's Avatar
Re: 48 Burb, bagged, 5.3, 20 year wait
Originally Posted by youngrodder View Post
Wow I must have been tired. The post I made in your tread was intended for my left for dead build thread. I will delete it (if I can) from yours and move to mine...Yes it bolts over the existing rails. When you consider the amount of kits on the market that they have sold I'm not worried. I might box the frame rails though. What you are also not seeing is the center cross member where the rear rails tie into. This is a very robust piece.
Thanks on the job comment. It is 6.5 miles from my house and I can drive the 48 to work quite often.
Marc
Please feel free to leave the pictures here Marc. Adds interest since I am not doing any building right now.
Nice short commute and driving the 48 often have to be great!
Advanced Design is offline   Reply With Quote
Old 07-29-2015, 09:09 PM   #677
youngrodder
youngrodder's Avatar
Yes, I'm using it as a marketing tool tomorrow for the company I work for when I drive it to go talk to this Jeep shop close to us. They make a bunch of Jeep parts. I'm going to air it down when I pull in and ask if they make a lift kit for it..ha ha ha
Marc
…………...........__________
.................. ((__|__||___\____
..;.;;.:;:;.,;..;((_(O))____ (_(O))
1948 Chevy Truck - Finished SOLD!!
1953 Chevy Suburban "Family Truckster" Completed: Spring of 2021
http://67-72chevytrucks.com/vboard/s...d.php?t=605484
1994 4x4 Blazer - "Field Find"
https://67-72chevytrucks.com/vboard/...ferrerid=30857
youngrodder is offline   Reply With Quote
Old 08-29-2015, 05:09 PM   #678
Advanced Design
First off guys, thank you for the prayers and positive thoughts for my wife. We were in Cleveland for nearly a month. Been home almost a month and she is gaining in strength every day. Three more months of treatments then monitor. We went from no hope to hopeful. He is answering our prayers!
Finally had a little time on the Burb today, playing with the air tank mounting.
Need your input guys. Chizzler and others have mounted the tank on the outside of the frame below the drivers door. The diameter is OK however the 30" length on this tank is too much due to running board brackets. Since it is really tight inside the frame and I don't want to mount inside I am kicking around these options.
1. Use two shorter tanks, one left and one right in this location.
2. Move the running board bracket behind the body mount and use this tank.
The rear running board bracket will be moved forward to clear the parallel four link.
Appreciate your thoughts and ideas!
Old 08-29-2015, 09:45 PM   #679
youngrodder
Glad things are looking up on your wife's health. As for the tank location, just get it right because then I can follow your lead and save myself the headache.....
Marc
Old 08-29-2015, 10:38 PM   #680
Advanced Design
Marc
Thanks Marc! Will do my best...
Old 08-29-2015, 11:44 PM   #681
99 to Life
99 to Life's Avatar
glad to hear about your wife. as for tank.... I'd find a location where you can access it the best you can. If that is your only option right there. I'd opt for two tanks. One 5 gallon tank (actually less than 5gallon even though they say 5g) would air you up maybe twice before comps kick on, just my guess. I'v been having to air up and down while driving here in PA cause the roads suck. So my 5 gal tank isn't the best or worst. My two 450 viaairs take about 5 min to fill from zero.
51' 99toLife finished 2011,355 sbc,5speed, patina, redoing whole truck, inter, bags, etc
http://67-72chevytrucks.com/vboard/s...d.php?t=382481
49Hardtimes s/10 susp- bagged, vortec sbc, 5 speed, patina, sold
http://67-72chevytrucks.com/vboard/s...d.php?t=594874
VIDEOS https://youtu.be/E8zHhjgS_lA
Geronimo 54' LS engine, static drop IFS, Client build, just about done
http://67-72chevytrucks.com/vboard/s...62#post7399162
52' 3100 Slowly in progress, will be painted two toned, have 235 with a t-5, lowered OG frame
Other projects, 49' farmuse 3100, killer Patina, will be slammed, LS engine, full done interior up next!
www.coffeeandcustoms.com
99 to Life is offline   Reply With Quote
Old 08-30-2015, 09:41 AM   #682
oldman3
oldman3's Avatar
Doug, glad Cindy is doing so well. Wish I could help, but no nothing about air systems...Jim
oldman3 is offline   Reply With Quote
Old 08-30-2015, 12:48 PM   #683
65sub
65sub's Avatar
I'm glad things are looking better with your wife's medical situation. For the tank installation I'd opt for one tank, less complicated and you don't have to buy two more tanks. Does the tank in the picture tuck up higher? Otherwise it might be a low point.
Dale
My suburban's Twisted Little Sister
http://67-72chevytrucks.com/vboard/s...d.php?t=655167
65sub is offline   Reply With Quote
Old 08-30-2015, 01:19 PM   #684
joedoh
joedoh's Avatar
looks like the running board will be 3-4 inches lower than the tank in the position its in, so low point may be a relative term
I wouldnt move the running board bracket but I only say that because its just extra work. is there room inboard? where are you putting your gas tank? on my 65 the gas tank was inboard on the left and I could have put a couple air tanks on the right.
I also agree with 99tolife, that a smallish tank will have faster recovery but you will run out of air on about every lift. have you picked compressors? I would consider an engine driven compressor over electric, and with a small tank recovery time is seconds, not minutes. if you are planning on a 5-6 gal tank, get an EDC I guess is the point I am making.
prayers for your wife! I would be lost without mine, so heres to you
Old 08-30-2015, 01:51 PM   #685
Advanced Design
Thanks 99! This location "seems" good though is pretty tight. And it is a no go once the middle running board bracket is installed. It will be difficult to connect the lines as well. I had one compressor and a 5 gallon tank on the truck...took to long too air up and raise.
Thanks Jim! Prayers being answered! Jim, I know very little. I do know the next build will be on springs!
Appreciate that 65sub! I prefer the one tank approach too. The tank will tuck up more if I change the mounting bracket and move the running board bracket. Thinking I will find another solution.
Thanks Joedoh...she is the center of my universe since 1978. Glad she figured I was a keeper!
Inboard of the frame will get really tight. There is less ...or seems less...height space than on the truck. There might be room if I noodle on it more. I have three electric compressors already. They sent me one too many and I've tried to send it back. Anyway, the 5 gallon tank should be filled OK with the two compressors.
The gas tank will be at the rear (I think) between the frame rails. I could mount the tank and compressors inboard on left side and possibly run exhaust pipes on the right side. Not wild about that option though.
Thanks for the input and ideas guys. Lot's of smart creative people here and I appreciate your help...I need all I can get!
Old 08-30-2015, 05:11 PM   #686
CHIZZLER
SAVING ONE TRUCK AT A TIME
CHIZZLER's Avatar
My tank is only 20" long and fits well. It looks like you would have room to drop it down and back. The lowest point on the truck would be the bottom of the running boards brackets. Glad your wife is doing better.
53-suburban (99% done)
40-pick up (99.9% done)
12-cc lb dually D-max (dd)
61-crew cab D-max
"PAY LESS FOR WHAT YOU NEED PAY MORE FOR WHAT YOU WANT"
53 BURBAN BARN FIND:http://67-72chevytrucks.com/vboard/s...d.php?t=404091
1940 PROJECT MOON SHINE:http://67-72chevytrucks.com/vboard/s...d.php?t=551088
1961 CREW MAX: http://67-72chevytrucks.com/vboard/s....php?p=6957999
CHIZZLER is offline   Reply With Quote
Old 08-30-2015, 05:35 PM   #687
Advanced Design
Thanks Chizzler. Good point about the bottom of the running board brackets. Joedoh mentioned that too. I can go down a little more. This tank is 30 inches and a 20 inch tank would clear. Is yours a 3 gallon tank? Prayers for your wife too.
Old 08-30-2015, 06:19 PM   #688
CHIZZLER
CHIZZLER's Avatar
I believe the tank is also a 5 gallon. It barely fit between the frame and running boards. Thanks for your prayers. Wife is doing better.
61-crew cab D-max
Old 08-30-2015, 09:10 PM   #689
Iceburgh
Iceburgh's Avatar
curious on your tank as well.
I now have mine up on jack stands and waiting for airride to come in, should be here this week.
I am way to low....I scuffed the bottom of the fender pretty good. Before I do any more damage I took off the drop spindles and will go with shockwaves.
Much better than doing bodywork and repaint.
So far I have had to repiant the fender and the hood
1953 suburban build
http://67-72chevytrucks.com/vboard/s...d.php?t=621331
Iceburgh is offline   Reply With Quote
Old 08-30-2015, 09:34 PM   #690
Advanced Design
Wow, fender and hood repaint...what happened to the hood?
I will follow Chizzler's lead and size out a 5 gallon tank 20 inches long. Will try it where I show the 30 inch tank. Hopefully the diameter won't be too large and will clear the running board.
Iceburgh, please share what direction you go too. Thanks!
Old 08-30-2015, 10:48 PM   #691
99 to Life
99 to Life's Avatar
Id have to go back and see how your suspension is laid out again to give any input on a relocation. Even thought that tank isn't the "lowest" point, its still highly vulnerable to getting hit, and if its tight squeeze, wouldn't be fun replacing or getting to it. But... sometimes you have no options. Before I put mine where it is, I was seriously considering putting it behind my seat. bottom line, a 5 gallon tank really isn't 5 gallon, and two comps is a MUST, which also adds to the chaos of placement and more wiring.
also the way the tank is clocked, there wouldn't be a port to have a drain valve. I think that it would be best to clock in a position for that. Although, I just opened up my drain valve and nothing came out at all, and its an aluminum tank, been putting air to it since winter.
Old 08-31-2015, 04:57 AM   #692
lower50's
lower50's's Avatar
I know my frame is different but I have 2- 4 gal. They are a spun aluminum tank you can get them 18", 24" mine and 28" long.
http://67-72chevytrucks.com/vboard/s...d.php?t=648459
https://67-72chevytrucks.com/vboard/...d.php?t=769441
1951 MG TD
1967 Jeep CJ5 1.9L TDI 33X13.5X15 Mud Grapplers.
1952 GMC 9700 p/u 7.3L diesel on air, dually
lower50's is offline   Reply With Quote
Old 08-31-2015, 10:29 AM   #693
Advanced Design
Thanks 99. Good point about the clocking for a drain port. Will be sure to do that. This is one I will have to play around with I think. Really appreciate the input.
Old 08-31-2015, 10:34 AM   #694
Advanced Design
Appreciate the ideas lower50's. This is one I may need to pursue. Looks like a nice set up you put together!
Attachment 1442296
Attachment 1442297
Old 08-31-2015, 11:33 PM   #695
CHIZZLER
CHIZZLER's Avatar
This is about the same tank I used. Look at the dimensions.
http://www.ebay.com/itm/5-Gallon-8-P...ff7135&vxp=mtr
61-crew cab D-max
Old 08-31-2015, 11:44 PM   #696
99 to Life
99 to Life's Avatar
buzz is in my back yard practically. what is your max length you can go?
I like this tank, esp for you, you can kick it side ways and have a drain port still
http://www.ebay.com/itm/Air-Zenith-5...3D111394262390
Old 09-01-2015, 08:52 AM   #697
Advanced Design
Thanks Chizzler!
5 Gallon 8 Port Air Tank
Looking for more air? The five gallon tank offers the perfect amount of air storage to run train horns, pneumatic tools and other on-board air applications. Equipped with 8 half inch ports, this tank allows for many high-flow applications that could prove difficult with the smaller sized ports found on smaller tanks. It is also rated to twice its working pressure of 150 PSI, while meeting all DOT standards, and stands on legs for easy mounting options.
Specifications:
Volume: 5 Gallons (18.93 Liters)
1/2" Ports: 7
3/4" Port: 1 On Face
Rated Max Pressure: 300 PSI
Working Pressure: 150 PSI
Burst Pressure: 800 PSI
Length: 20.5 in (520.7 mm)
Diameter: 9.5 in (241.3 mm)
Height: 11.5 in (292.1 mm)
Weight: 20 lbs (9.07 Kg)
Old 09-01-2015, 08:57 AM   #698
Advanced Design
Than you 99! I might have 25 inches. Will install the running board bracket and make sure.
5-gallon aircraft-grade aluminum 300psi burst proof air tank. 8 ports: 4x 1/2", 4x 1/4".
Old 09-23-2015, 08:14 PM   #699
mr incredible
mr incredible's Avatar
just found this... i will be looking forward to your progress
USN RETIRED
there are two things you don't need in the navy. that's a wife and a pick up truck. cause when your out to sea someone else is using them
mr incredible is offline   Reply With Quote
Old 09-23-2015, 10:23 PM   #700
Advanced Design
Welcome aboard mr incredible. With the yard work slowing down, I am planning some shop time Saturday to take another run at mounting the air tank and compressors.
Thanks again for the input and ideas guys. Really appreciate all the help.
