Old 08-31-2015, 07:20 AM   #1
chrismoore701
chrismoore701's Avatar
Bleeding the proportioning valve
I am moving to the brakes on my 79 C10 Frame off. I have a new booster, master cylinder and proportioning valve. I have heard you need to bench bleed your master cylinder and bleed the proportioning valve. I assume I just fill the master cylinder up with fluid and compress the piston a few times, but how do you bleed the proportioning valve?
Chris
_______________________________
1979 Chevy Stepside SPORT
2018 Chevy Silverado, 39 years apart
My build 2008-2016. http://m.imgur.com/a/bURrE
chrismoore701 is offline   Reply With Quote
Old 08-31-2015, 11:54 AM   #2
geezer#99
geezer#99's Avatar
Re: Bleeding the proportioning valve
You don't bleed the prop valve!
But you do need to depress and hold in the reset button on the front of the prop valve while you bleed the brakes.
geezer#99 is online now   Reply With Quote
Old 08-31-2015, 01:57 PM   #3
chrismoore701
I have a plastic plug tool thing that came with it. Do I just screw this in while bleeding?
Chris
Old 08-31-2015, 02:18 PM   #4
geezer#99
geezer#99's Avatar
We need a pic!!
Old 08-31-2015, 02:23 PM   #5
motornut
78K & 79C Jimmys
motornut's Avatar
could be to keep dirt out during shipping?
John
1978 GMCJimmy4X4-350/203
1979 GMCJimmy4X2-305/350
Old 08-31-2015, 11:21 PM   #6
chrismoore701
Here ya go
http://m.ebay.com/itm/CHEVY-GM-Propo...851?nav=SEARCH
I here you just screw it in while bleeding
Chris
Old 08-31-2015, 11:38 PM   #7
geezer#99
geezer#99's Avatar
With that style prop valve you do.
Keeps the piston centered so you have fluid front and back.
Old 09-01-2015, 01:24 AM   #8
craig113
I copied the part from the article below. But the link to the whole article is http://www.classicperform.com/TechBo...t.htm#testprop It seems very good and covers alot of brake problems. I hope it works.
Test Combination/Proportioning Valve
Use a test light by attaching a clip to a positive contact on the vehicle and touch the point of the tester to the electrical connection of the combination valve. If the the light does not come on, the valve system is operating correctly and no further testing is required.
If the light does come on, this indicates that the pressure differential valve is stuck in the front or rear position.
Bleed the brake system to determine if the front or rear lines are blocked off. Set up one front wheel and one rear wheel for bleeding at the same time. Crack both bleeder screws and gently pump the pedal a few times.
The blocked side will trickle fluid out when the bleeder screw is cracked and the pedal pressed. An unblocked line will squirt fluid out the bleeder.
The lines that are clear must be left open and the blocked lines should have the bleeder screws tight to cause pressure to build up on that side. Be sure to use the standard bleeding procedures to prevent air from entering the system.
Slowly press the pedal with steady pressure a number of times until the light goes out; this will center the differential valve. You may also hear a pop come from the proportioning valve. This is the metering valve returning to its equalized position. When the light goes out, close the bleeder screw.
put a 2x4 under your brake pedal, to keep from over stroking you could get buy without the tool assist
84 K30 CC LB Fleet side 454/400/205/14 bolt Rebuilt 2200 miles
91 K15 Z71 SB 350/700r/241c/12 bolt 372k miles
96 K15 Sub 350/4L60/243c/10 bolt 333k miles
craig113 is offline   Reply With Quote
Old 09-01-2015, 07:10 AM   #9
chrismoore701
Chris
