Old 09-05-2015, 12:46 PM   #1
1adam12
1adam12's Avatar
Thumbs down have a headlight issue
On my 70truck I am having a issue. When parking lights on all lights work perfect but when j pull the headlight switch headlights come on and I lose all other lights. No running lights no interior lights I just replaced the switch and all fuses are good any suggestions???? Thanks
1adam12 is offline   Reply With Quote
Old 09-05-2015, 01:00 PM   #2
ssxty8
Lightbulb Re: have a headlight issue
Make sure you have all the related grounds connected.
ssxty8 is offline   Reply With Quote
Old 09-05-2015, 01:36 PM   #3
D-rock1981
D-rock1981's Avatar
Probably not what you want to hear, but if you have original wiring I would recommend a complete rewire of the entire truck. I've seen to many nice rides burned up because of 50 year old corroded wires. At least rewire your headlight circuit to use a relay, and not run all the current through the switch.
D-rock1981 is offline   Reply With Quote
Old 09-05-2015, 02:07 PM   #4
GASoline71
"I ain't nobody, dork."
GASoline71's Avatar
Check the dimmer switch on the floor. Many headlight related problems have stemmed from a faulty dimmer switch.
Gary
'cuz chicks dig scars...
I would never rebuild a 305.
Old 09-05-2015, 02:11 PM   #5
leddzepp
Moderator
leddzepp's Avatar
Gary
Agree. This was the culprit when I had headlight issues.
1972 C/10 Cheyenne Super SWB. Restored, loaded, slammed.
1968 C/10 50th Anniversary LWB. Unrestored, stock, daily driver/work truck.
RIP ElJay
RIP 67ChevyRedneck
RIP Grumpy Old Man
RIP FleetsidePaul
