Old 09-07-2015, 10:08 AM   #1
chopit
chopit's Avatar
s10-AD swap brake question
On my 1995 s10 brakes, mounted on the driver firewall is a big bulky unit with brake lines, wiring and connectors and bleeders. What is it and do I need it? There is a small block on a bracket at the booster that I assume is my proportioning valve?...but if the big conglomeration on the firewall is it, it is huge.
chopit is offline   Reply With Quote
Old 09-07-2015, 10:53 AM   #2
mr48chev
mr48chev's Avatar
Re: s10-AD swap brake question
Antilock brake setup? After looking at a 95 on Ebay 321814505811 I'd think that is what you have and if it were me I'd get a simpler Master cylinder/booster combination for an earlier S-10 or an aftermarket setup.
Most of the S-10 swap guys don't get into trucks that new as donor rigs so it isn't a big issue yet.
My ongoing truck projects:
Old 09-07-2015, 11:15 AM   #3
chopit
chopit's Avatar
Thanks mr48chevy. Yeah it finally dawned on me its the ABS setup. Not used to late model stuff. Just wasn't thinking.
I wouldn't think it would be a problem to use the master and booster tho? just eliminate the ABS and get an early proportioner?
Old 09-07-2015, 12:42 PM   #4
chopit
chopit's Avatar
O...and when I said firewall I meant fenderwell...didn't catch it in the edit.
Old 09-07-2015, 03:43 PM   #5
BlueJeep
BlueJeep's Avatar
Correct, master and booster are OK to use.
build threads:
86 Suburban
88 Jeep 6.0 swap
49 Chevy truck
54 Chevy wagon
86 Suburban lowered 4/6
54 Chevy wagon
49 Chevy/s10 mix
88 Jeep Wrangler rockcrawler
BlueJeep is offline   Reply With Quote
Old 09-07-2015, 07:51 PM   #6
chopit
chopit's Avatar
Thanks BlueJeep
Old 09-07-2015, 11:30 PM   #7
mr48chev
mr48chev's Avatar
I don't know how those are set up so I am no help on work or no work as far as the master cylinder and booster. My only experience in that area is on a 91 Dodge mini van and the anti lock setup was a mega dollar contraption that even if you replaced it you weren't guarenteed it would work. I replaced that setup with a stock booster and master cylinder and ended up using my junk yard pieces for cores.
Old 09-08-2015, 06:02 AM   #8
msaintg
msaintg's Avatar
I had that exact same problem when I used a 1996 S10 Blazer as the donor vehicle. here are some before and after pics from removing the anti-lock brake unit. Brakes work great without it... just has the light on the dash always lit.
msaintg is offline   Reply With Quote
