Old 02-17-2004, 03:00 PM   #1
ocbaud
Garage Queen Material
manifold vacuum fitting?
will the stock "t" manifold vacuum fitting clear with a holley carb?
ocbaud is offline   Reply With Quote
Old 02-18-2004, 09:49 AM   #2
ocbaud
ttt
Old 02-18-2004, 12:22 PM   #3
low 84
low 84's Avatar
are you talking about the vaccum fitting for the trans modulater thats behind the carb? if so then i wouldn't count on it fitting. i ran a 700 dp and an edelbrock intake before and had to use a 1 inch carb spacer for the rear bowl to clear the fitting. but different intakes locate the fitting at different heights so it depends on what intake your using
'51 F100, backhalf with a narrowed 9 and coil overs, 18.5" mickeys, monte front clip, +400" sbc in the works
'05 1500 Crew Cab
RIP
'84 swb 5/7 drop, solid cammed 408 w/ fully ported dart heads, th350 w/ 10 inch hughes, 12 bolt w/ 3.73 richmonds and a locker
'80 swb 4x4 in progress: 7" lift, 350 th350/np205, d44 and 1.5" ORD tie rod, 14BFF w/discs , armored diff covers, 40" MTR's
low 84 is offline   Reply With Quote
Old 02-18-2004, 02:35 PM   #4
Joe Rae
T
Mine didn't clear, however, it did after I cut the horizontals down slightly.
Joe Rae is offline   Reply With Quote
