Go Back   The 1947 - Present Chevrolet & GMC Truck Message Board Network > General Truck Forums > All 4x4 Tech & Off Roading > 4x4 Projects and Builds
Old 08-28-2015, 04:31 PM   #26
MetalWorks
Re: 1972 c10 conversion to a LSA powered k20 build thread
Hung the rest of the major sheet metal so we could lay out the Cheyenne trim...lots of holes drilled!!!
MetalWorks is offline   Reply With Quote
Old 08-28-2015, 09:27 PM   #27
Bladeboy1998
Man that is going to be one sexy truck!
Bladeboy1998 is offline   Reply With Quote
Old 08-29-2015, 04:46 PM   #28
71blksuper4x4
SWB 4x4 Collector
71blksuper4x4's Avatar
While it is still at this stage, you guys misplaced the "super" emblem on the driver's side. Common mistake seen on restored trucks. It always goes under the Cheyenne portion of the emblems on both sides, not more on the right hand side. Just thought I'd help ya out ahead of paint. Trevor
TREVOR
1970 CST swb 4x4 (speedwarning,cruise,tilt,tach,8track, original red shoulder belts,tow hooks)
1972 Jimmy (soon to be Hickey cloned)
1971 Cheyenne Super 4x4 swb (tilt,tach,buckets, original blue shoulder belts,am/fm,cruise,tow hooks, dealer 8 track)
1972 Cheyenne Super K20 4x4 Custom Camper (tilt, tach, am/fm, tow hooks, bed toolbox, aux gas tank
1972 Cheyenne Super Crew Cab K30 4x4 Duramax, Allison, np205, buckets, tow hooks (CURRENT PROJECT)
http://67-72chevytrucks.com/vboard/s...d.php?t=624819
1989 V3500 Crew Cab (454tbi, NV4500, np205)
1970 Chevelle SS (LS5 454,th400,8track,buckets,tach)
:2004 Jeep Wrangler Rubicon (daily driver)
WTB: 1968-70 Cruise Control Lever
71blksuper4x4 is online now   Reply With Quote
Old 08-29-2015, 04:49 PM   #29
71blksuper4x4
SWB 4x4 Collector
Project is looking good though.
TREVOR
Old 08-30-2015, 01:33 PM   #30
19silverado77
Is it going to be stock height or is there plans for a lift? And if lifted what tires/ wheels will you guys be using.
19silverado77 is offline   Reply With Quote
Old 09-01-2015, 07:14 PM   #31
MetalWorks
The truck will be getting a 4" lift kit, and I believe the tires are 285/75/18...they are at the tire shop right now, so I can't look...but I do know they are 34" tall.
Old 09-02-2015, 06:50 PM   #32
MetalWorks
We trimmed, and capped the front fenders for clearance.
Old 09-08-2015, 12:29 PM   #33
MetalWorks
Put in the new 4" lift springs, then mocked up the motor and transmission.
Old 09-09-2015, 12:32 AM   #34
Nitis
Nitis's Avatar
is that a 73-87 chassis?
Nitis is offline   Reply With Quote
Old 09-09-2015, 11:40 AM   #35
MetalWorks
Nitis...no, the chassis is a 72 4x4.
Old 09-09-2015, 11:52 AM   #36
Nitis
Nitis's Avatar
Maybe I don't understand. The LSA is just like any of the other LSX blocks right? How are you mounting the engine thought you needed a modified crossmember
Old 09-09-2015, 11:59 AM   #37
MetalWorks
The engine compartment was then mocked up with the radiators, fans, and other misc components for clearance and mounting points. The guys also fabricated a custom engine cradle for the LSA.
Old 09-09-2015, 12:02 PM   #38
MetalWorks
Nitis...yes, ha ha...you are just one step ahead of me...here is the custom engine cradle for the LSA engine.
Old 09-09-2015, 12:04 PM   #39
MetalWorks
Here is the custom engine cradle for mounting the LSA engine.
Old 09-09-2015, 12:16 PM   #40
Nitis
Nitis's Avatar
Ok though maybe you found a top secret way. This amongst other things is why I'm leaning away from an lsx swap. Wish I had your tools and skills. That is gunna be one sweet ride
Old 09-09-2015, 01:35 PM   #41
Daubs
Daubs's Avatar
Outstanding!
'72 Chevy K-20 Crate 350, SM465, 4.10's
Daubs is offline   Reply With Quote
Old 09-09-2015, 11:12 PM   #42
ryanroo
ryanroo's Avatar
Looks sweet!
72 K20 12v build
72 K20 "parts truck"
ryanroo is offline   Reply With Quote
Old 09-10-2015, 02:47 PM   #43
MetalWorks
Thanks a lot guys...the truck is really coming along nice.
Here we cleaned up the rest of the frame to get it ready for sand blasting, and fabricated mounts for the gas tank.
Old 09-14-2015, 03:59 AM   #44
Nitis
Nitis's Avatar
what gas tank are you using?
Old 09-14-2015, 04:06 PM   #45
MetalWorks
It's a TANKS inc gas tank, but we had to do a good amount of modifying to mount it.
Old 09-24-2015, 12:33 PM   #46
MetalWorks
We mocked up more components to the truck's cab, and started on its body work.
Old 09-24-2015, 12:34 PM   #47
MetalWorks
Body working the cab...
Old 09-25-2015, 04:47 PM   #48
MetalWorks
All the mods are done to the frame, so it was sent off for sand blasting...looks nice.
Old 09-25-2015, 04:50 PM   #49
MetalWorks
Meanwhile it was a big day for the cab...we seam sealed it, then it was off to paint!!!
Old 09-25-2015, 11:03 PM   #50
swamp rat
swamp rat's Avatar
Looks sweet!
Mike.
Swamp Rat build thread :
http://67-72chevytrucks.com/vboard/s...d.php?t=595019
72 3/4T 4X4
4" BDS Lift
33" BFG's
swamp rat is offline   Reply With Quote
1972 chevy, 4x4 conversion, k20, ls conversion, supercharged
