Old 09-09-2015, 08:13 PM   #1
olebluegmc
Is undercoating good or bad ?
I was planning on coating all my patch panels with 3m undercoating where it won't be getting welded, like my cab mounts, and rockers on the inside where it won't get welded. I Thought this would be good to prevent future rusting out of these troubled areas, however I was talking to a mechanic at work and he said undercoating causes more rust because the moisture can get trapped underneath and expedite rusting. Looking to see if anybody has had good or bad issues with undercoating ?
olebluegmc is offline   Reply With Quote
Old 09-09-2015, 08:25 PM   #2
hugger6933
Re: Is undercoating good or bad ?
I think your guy has it wrong the undercoating prevents the moisture getting next to the metal. But with that being said if you put it on and weld close to it it can/will melt away from that area. If you leave a big portion untreated so not to get burned what would be the use in some if not all? My ideas I will submit is to use weld through primer then you want extend it out past the areas to be welded then undercoat the parts away from the heat. Or treat the entire panel with weld through. Any way you go is a better than what they had as in nothing.
hugger6933 is offline   Reply With Quote
Old 09-09-2015, 09:22 PM   #3
tommys72
tommys72's Avatar
Just get an oil leak like I got, it'll undercoat everything for you! Haha
United States Marine Corps 2000-2011
Iraq and Afghanistan veteran
Just living life now and enjoying it and my wife, daughter and son
tommys72 is offline   Reply With Quote
Old 09-09-2015, 10:11 PM   #4
jocko
jocko's Avatar
If you've got it rust free and are gonna park it inside - I'd skip the uc. If you're gonna drive it in salt, might consider it, otherwise no. Might want to look for another mechanic... JUST kidding. Actually, maybe he's onto something - several of these trucks I've seen that had uc, I noticed when I peeled it's dry, rotted, mess off that there was rust underneath. Hmm. Ok, give that man a raise. Bottom line, I wouldn't undercoat it anyway.
Old 09-09-2015, 10:19 PM   #5
agawam
3M undercoat will cost a lot , its not cheap, what I use is non fibered roof tar mixed with a little gasoline, it is a real petroleum product ,the gasoline aides in drying, you can handle it in about a hour, dries like paint, spray out of a body shutz gun, a gallon at home depot is around 16 bucks an goes a real long way
agawam is offline   Reply With Quote
Old 09-09-2015, 10:29 PM   #6
Wrenchbender Ret
I think black satan paint looks a lot better. If the metal has surface rust, spray it with Rustoleum Rusty metal primer.
Wrenchbender Ret is offline   Reply With Quote
Old 09-09-2015, 10:33 PM   #7
olebluegmc
I was mainly planning to do it on the inside of the cab mounts/ supports since I have access and am putting new ones. They seem to rust out on the bottom and sides from debri so I thought it might be a rust deterrent.
Old 09-09-2015, 11:23 PM   #8
englands 71
englands 71's Avatar
Undercoat has been used for years and worked very well. However it gets dirty and hard to clean. If you like the look and can handle the dirty look after awhile I say go for it.
If you're stripping it , painting the bottom of the cab and doing a detailed job , why cover it up ? I painted the bottom of my 67 red but my 71 I just sealed and painted it flat black.
englands 71 is offline   Reply With Quote
Old 09-09-2015, 11:32 PM   #9
69chevy lwb
69chevy lwb's Avatar
Good undercoating is fine but expect it to become dirt colored. I prefer por15 and I use 3m aerosol undercoating for the places you just can't reach like the insides of cab corners ect. It is possible for the undercoating to cause problems. I have a utility bed that was undercoated and the whole bottom is rusted away. When you peel the undercoating back it's full of dirt and rust. But who knows how it was prepped before hand
69chevy lwb is offline   Reply With Quote
Old 09-10-2015, 12:42 AM   #10
boynton
boynton's Avatar
The only parts on my one owner short step that weren't rotted away were under coated. If you get your parts nice and clean hit then with some primer weld everything up and a second coat of primer and then undercoat. Make sure you get every area covered and covered well. Where you see problems is where a section doesn't get covered and then the rot starts. Undercoating is a must if you're going to drive it.
Just trying to figure this out...
1970 SWB Step-Side
http://67-72chevytrucks.com/vboard/s...d.php?t=552980 1970 LWB
http://67-72chevytrucks.com/vboard/s...d.php?t=584499
1970 SWB One Owner Step Side 6.0 LY6/6L90
http://67-72chevytrucks.com/vboard/s...d.php?t=617630 Junkyard's 1971 short wide
http://67-72chevytrucks.com/vboard/s...86#post7531186
boynton is offline   Reply With Quote
Old 09-10-2015, 02:30 AM   #11
mike16
under coating was good...even 43 years ago in AZ. so it cant be bad for the next 43 years either.
inside the cab... On a hot day? things could get kinda messy
mike16 is offline   Reply With Quote
Old 09-10-2015, 04:53 AM   #12
Xeen
Xeen's Avatar
Buy a small can of POR-15 and coat liberally and it likely won't ever rust again.
Please call me Brian.
Check out My 1972 SWB Fleetside 5.3L Vortec Restomod Build
Xeen is offline   Reply With Quote
Old 09-10-2015, 12:19 PM   #13
dfwright
dfwright's Avatar
I will say that the areas under the bed which had good covering of the original undercoat, the metal under it was very clean. It was a bear getting the stuff off, but it convinced me of the value. Unfortunately, the application of the factory undercoat was "haphazard" at best.
1972 C10 LWB, 350/350
Deconstruction began 5/2009, mostly completed restoration, 5/2017
dfwright is offline   Reply With Quote
Old 09-10-2015, 02:19 PM   #14
sboris
sboris's Avatar
Im all in on the por-15. Its non porous. Good stuff. Is what i used, and they make an aerosol now for those hard to reach areas like mentioned above.
Shawn
68 chevy K/20
05 chevy 3/4 4x4
71 short step-sold
71 chevy Beauville van
My build.
http://67-72chevytrucks.com/vboard/s...d.php?t=633039
sboris is offline   Reply With Quote
Old 09-10-2015, 02:25 PM   #15
olebluegmc
I'm planning to use raptor liner for the entire bottom of the cab as well as the floor inside, I love the look and I've heard great things. I think I'm gonna go for it and use the 3m aerosol can to coat the inside of my cab supports, cowl ( while I have it open for repair), and any other areas I won't be able to get with the rapor liner
Old 09-10-2015, 08:00 PM   #16
Jrainman
Jrainman's Avatar
I would use short strain fiberglass( cat hair) on your floor patch seams as a base this will fill and seal all your small gaps and pin holes then prime and top coat with your choice
Jrainman is offline   Reply With Quote
Old 09-10-2015, 09:19 PM   #17
flipper58
flipper58's Avatar
I can only say what some others above have said about undercoating: it preserved the heck out of my truck. The original undercoating (either factory or Ziebart back in October 1970 when the truck was purchased) did one hell of a job keeping my truck clean. It is a slight pain to use a heat gun and mineral spirits to clean it up, but once it is clean, man the results are surprising. I mean over 45 years later and metal and paint are pristine. Unbelievable.
Phil
http://67-72chevytrucks.com/vboard/s...d.php?t=657946
flipper58 is offline   Reply With Quote
