Old 09-04-2015, 07:19 AM   #1
kingstrider
kingstrider's Avatar
WTB small block AC radiator shroud
Looking for a small block radiator shroud for an AC truck. If anybody has one in decent shape let me know. Thanks!
kingstrider is offline   Reply With Quote
Old 09-04-2015, 11:10 PM   #2
kingstrider
Re: WTB small block AC radiator shroud
Bump
Old 09-04-2015, 11:51 PM   #3
1968k20
1968k20's Avatar
Have one out of a 72 Suburban, sb 400
1968k20 is offline   Reply With Quote
Old 09-05-2015, 06:14 AM   #4
kingstrider
Do you have photos?
Old 09-05-2015, 09:04 PM   #5
1968k20
1968k20's Avatar
Photos for kingstrider
Old 09-05-2015, 09:06 PM   #6
1968k20
1968k20's Avatar
#2
Old 09-05-2015, 09:10 PM   #7
1968k20
1968k20's Avatar
#3
Old 09-05-2015, 09:13 PM   #8
1968k20
1968k20's Avatar
#4
Old 09-05-2015, 10:11 PM   #9
Todd68Chevy
Todd68Chevy's Avatar
That looks like a big block shroud to me.
Note: All parts I have for sale are also for sale locally.
I currently own: 1940 Chevy Fire truck (project), 1946 Chevy truck (project), 1946 Chevy 1 Ton pick up, 1953 Chevy school bus (storage area), 1968 Chevy C10 (I have drove for 26 years), 1994 Chevy C2500 (daily driver), 2005 GMC crew cab K2500 (parts hauler) and more trucks for parts.
Todd68Chevy is offline   Reply With Quote
Old 09-05-2015, 10:58 PM   #10
1968k20
1968k20's Avatar
I pulled it off of a '72 Suburban with a 400 in it. Might someone have put the wrong one it?
Old 09-05-2015, 11:12 PM   #11
Todd68Chevy
Was the engine there or are you going off a fender emblem that reads 400? The 400 fender emblem were used on the 402 big block trucks. As far as I know they never installed a 400 small block in a 1967-1972 truck from the factory. I would say it had a 402 big block in the Suburban originally.
Old 09-05-2015, 11:22 PM   #12
Todd68Chevy
Do you have a 3 core or 4 core radiator? I believe they are different. I need to check the condition and remove it from the truck but I have a 4 core small block with a/c shroud on a truck I just brought home this week.
Old 09-06-2015, 01:46 AM   #13
kingstrider
1968k20 that looks like a big block shroud so won't work for my intended fan setup.
Todd68Chevy, I will have to look to be sure. Is there a difference in the shroud between a 3 core or 4 core? I'm interested, let me know when you get it out.
Old 09-06-2015, 09:16 AM   #14
1968k20
1968k20's Avatar
I guess I will have to change my post!
Old 09-06-2015, 10:47 PM   #15
Todd68Chevy
This is a small block with a/c and 4 core radiator. in good over all shape but is broken out at the left upper mounting tab. It was fastened in good but broken. $30 plus shipping if interested. Might work on a 3 core radiator but not sure. Last picture is showing the truck it came from and the size of the 4 core radiator. Thanks
Old 09-07-2015, 08:25 AM   #16
kingstrider
Hey Todd I checked and have a 4 core radiator. Is the mounting hardware in decent shape? Just to confirm does the shroud have the 19" fan opening? If so I will take it shipped to 29907.
Also how much for the radiator brackets and retainers?
Old 09-07-2015, 04:38 PM   #17
Todd68Chevy
Do you mean the upper and lower radiator mounts and the lower fan shroud clips or just the lower shroud clips? The lower radiator supports are rusty but check solid. Rubbers inserts are worn. For the fan clips and the upper and lower 4 core radiator mounting hardware $35.00
Fan shroud does have right at a 19" opening.
Let me look for another box and see if I can get the shipping price down because the best I am showing is thru UPS and it is $45.26 for the shipping. I guess I have not shipped any larger boxes lately but they must have raised the prices. I will see what I can do.
Old 09-07-2015, 06:23 PM   #18
71CHEVYSHORTBED402
71CHEVYSHORTBED402's Avatar
Curious of the shape that big block shroud is. Behind the dirt looks real nice. I may be interested. The one I have is nice, but it's missing the mold, located very top center.
Incidentally, if it's OEM as it appears, there should be a part number (e.g. 3924932).
Tony
71 Custom Deluxe, SWB, 2WD, 402, A/C. I developed an assembly kit for restoring the (a) truck from the ground up. My build thread, and more on the assembly kit https://67-72chevytrucks.com/vboard/...d.php?t=730025
71CHEVYSHORTBED402 is offline   Reply With Quote
Old 09-07-2015, 06:28 PM   #19
kingstrider
Sounds good I'll take those too. Tell you what, do me a favor and check shipping at www.shipnex.com (i.e. Worldwide Express). I have been using them for the last year or so for bigger, bulkier items like wheels, guitars, etc and the prices are usually less than FedEx or UPS, sometimes by half. But best of all, they actually subcontract through UPS so you can schedule a pickup with UPS or drop off at a retail store. Works great!
Old 09-07-2015, 07:23 PM   #20
Todd68Chevy
I have never heard of them before. If I am doing it right it is showing $23.86. Can you check and verify? The shipping from zip code is 47882, The box is 37" X 28" X 8" and approx. weight is 8lbs, 5oz. Thanks
Old 09-08-2015, 07:22 AM   #21
kingstrider
Sounds about right, I used those box measurements and rounded the weight up to 9lbs to show the same price shipped to me, or shipped to you.
I've been using them for about a year and they excel at shipping big and/or heavy items, usually for half the price of UPS. Just make sure to check the label when you print it off, sometimes it says UPS and others it says FedEx so you just need to drop the box off at the right location.
Old 09-08-2015, 08:17 AM   #22
Todd68Chevy
I will get it packaged up and check out the web site more but do you know if they will pick it up for free or is there a charge? Or can I pick UPS instead of Fed Ex? I have a UPS drop off within a mile or 2 of me but the closes Fed Ex is 25 miles away from me. I will see what I can find out.
Old 09-08-2015, 09:08 AM   #23
kingstrider
Pickups are free but the majority of the time the labels say UPS if drop off is more convenient. Thanks for your patience putting this together for me.
Old 09-09-2015, 09:27 PM   #24
Todd68Chevy
Ok, I finally have it packed. The size and weight is good so I will PM you the payment information. Thanks
