Old 09-06-2015, 05:06 AM   #1
fredscarryall
fredscarryall's Avatar
Extended doors on 50 pickup
Anyone doing or done extended doors on a 47 to 54. I need more leg room with a 4 inch set back firewall. I don't want to do the extended cab with side window look.anyone with pics or advice. I want to extend mine about 8 to 10 inches. Like this rough drawing
fredscarryall is offline   Reply With Quote
Old 09-06-2015, 10:26 AM   #2
Advanced Design
Advanced Design's Avatar
Re: Extended doors on 50 pickup
Interesting idea. There is a lot of curve front to rear in the door and the roof. Thinking to do it right, new door and roof skins with the correct curvature would need to be fabricated.
Advanced Design is offline   Reply With Quote
Old 09-06-2015, 01:26 PM   #3
mr48chev
mr48chev's Avatar
I'm extending my doors 9-1/4 inches to have the cab work with the standard short bed box on a long bed 1/2 ton frame (GMC frame).
Here is a cut and paste rendition of what it hopefully looks like. I used a photo of a truck that belongs to a guy about 100 miles from me as I didn't have a direct side shot of mine at the time and his has the same chop that mine does. This shows it chopped lengthened and sectioned though.
Another cut and paste using Cole Foster of the Salinas Boys old red truck.
My ongoing truck projects:
Old 09-06-2015, 06:24 PM   #4
donandal
I extended my 53 five window by 5 inches.
There are numerous sections to the door that needed to be extended,
including the area above the glass and the inner door panel.
I roll formed the upper door extension cross sections and then
added an extension to the door skin that I formed on my
english wheel. It has a compound curvature to match the original door skin.
The roof panel also required a compound curve panel to extend it.
The extension needs to be accurately executed to maintain the parallelism
of the window tracks also.
mine is just getting ready for paint this winter.
donandal is offline   Reply With Quote
Old 09-06-2015, 07:17 PM   #5
mr48chev
mr48chev's Avatar
Nice work, I plan to use the front half of one cab and the back half of another both to avoid two seams and the simple fact that I have one cab with a great firewall that is the one I want to use and a bad back side and another cab with a near perfect back side but not so good. The left overs will get used to fix other cabs that I have. I've got a stack of doors and don't really even know how many I have so each door will be made of two cut to fit with one seam.
Old 09-06-2015, 07:53 PM   #6
donandal
yeah,
that's probably the best way.
The cab also tapers wider as you move aft, so my back
panel of the cab was widened about an 7/8 inch.
the taper could probably handled a number of ways, but you will see
when the cab is split in half, and you need a longer section from
each donor cab to get the amount of extension you want, that you will see
about 7/8 inch taper for every 5 inches of cab stretch.
I just finished all my window track pieces and new glass patterns for the 5 inch extension, which also included extending the window roll up mechanism, and all new felt tracks and stainless exterior pieces.( which also needed to be extended). Also the inner door molding was extended.
but the legroom is awesome!
Old 09-06-2015, 08:54 PM   #7
donandal
also,
the doors seemed a bit flimsy after extending them.
I added a pair of custom box beams welded to
the inner door panel to strengthen it, and added a
custom curved door skin reinforcement beam to the outer skin
as well.
the outer beam is bolted in place, with mat applied for sound
deadening between the skin and the beam.
Old 09-07-2015, 12:05 AM   #8
mr48chev
mr48chev's Avatar
That is some nice work.
Old 09-08-2015, 04:14 AM   #9
fredscarryall
I agree with mr48chevy. Take. A good firewall front half and Good 5 window back and weld them together I think that would be easier because you can split the floors. Donaldal looks like you made the door extent easier then I was . I wiil have to use that idea
Old 09-08-2015, 12:38 PM   #10
MARTINSR
MARTINSR's Avatar
That is all looking good but the one thing I would do different, and this is a biggie is to "Z" cut the roof and door. Instead of going through the middle of the roof where it's the most difficult to weld you bring it over to the back where it's much easier.
This is the roof on my truck when chopping the top.
The same thing was done on the rear of the cab, there is no weld going through the middle of the cab when I sectioned it.
And the cowl.
The same idea on the door when they were sectioned. I cut the framing off the skin, sectioned the framing then simply re-rolled the skin welding to the frame and trimming the 2.5 inches off the bottom of the skin.
So I would think about bringing the cut back to the rear of the door like this.
Brian
1948 Chevy pickup
Chopped, Sectioned, 1953 Corvette 235 powered. Once was even 401 Buick mid engined with the carburetor right between the seats!
Bought with paper route money in 1973 when I was 15.
"Fan of most anything that moves human beings"
MARTINSR is offline   Reply With Quote
Old 09-08-2015, 01:01 PM   #11
_Ogre
_Ogre's Avatar
nice work... all of you
i thought of extending my cab thru the doors to give me some leg room
thought better of it after i had all the rust repairs done
way more work than i wanted to do
shop air compressor timer
Old 09-08-2015, 01:18 PM   #12
Advanced Design
Agreed, impressive work guys.
Any issues with matching the crown or curvature of the door or roof? I figured that would be a likely place for a flat spot or noticable curvature change.
Old 09-08-2015, 02:33 PM   #13
mr48chev
mr48chev's Avatar
Martinsr, I'm saving those photos to be able to show a buddy exactly what I have been talking about on the roof of my truck. Thanks.
I'll save the batch for reference. I had planned to do the doors the same way on the section too.
Advanced Design I've been pondering the difference in width of the cab when I stretch it 9-1/4 inches. I figure I'll have to do a bit of adjustment to get it all to match perfectly.
Old 09-08-2015, 02:58 PM   #14
MARTINSR
MARTINSR's Avatar
Here's a build thread on it if you want more. http://www.hotrodders.com/forum/1948...ar-233753.html
Brian
1948 Chevy pickup
Old 09-08-2015, 04:06 PM   #15
donandal
yeah,
Martinsr has a point about the roof weld in the middle.
It is a bit tricky.
I actually made a roof support beam for the contour
of the roof ( with my shrinker/stretcher ) before I welded
the main roof skin back in.
It was held in with clecos then removed for final welding.
It held the curve so well that i kept it and installed mat
between it and the roof and bolted it on just above the
door headers for a permanent support.
Old 09-08-2015, 04:16 PM   #16
MARTINSR
MARTINSR's Avatar
yeah,
It is a bit tricky.
I want to be clear, I am not saying what you did was wrong, you did an OUTSTANDING job on that project.
I have just found that moving the cut over to a better place pays off some big dividends. I certainly didn't mean to say anything negative.
Brian
1948 Chevy pickup
Old 09-09-2015, 12:51 PM   #17
donandal
Brian
Hey Brian,
I didn't take any offense.
I actually like your way better.
I don't have a lot of experience on this type of cab stretch.
It worked out ok, but you are right, that long weld across the top
really took a lot of time, a lot of patience, and a very deliberate process
to keep the whole top from warping.
probably the toughest part!
thanks
Old 09-09-2015, 01:26 PM   #18
MARTINSR
MARTINSR's Avatar
Hey Brian,
thanks
The first time I chopped the top on this truck I was 16. (This is another cab I replaced the old one)
The top needs to be lengthened when you chop it (or rake the posts) I welded it across the center and warped it all to hell! I put 2 gallons of bondo on that roof before I touched it with sand paper, NO KIDDING! LOLOL I actually Z cut it but not far enough. Plus of course I didn't know how to weld so I welded and cooled the welds BIG MISTAKE.
Brian
1948 Chevy pickup
Old 09-09-2015, 01:46 PM   #19
donandal
that's the patina I like.
not the truck itself, but those old photos.
too cool
Old 09-09-2015, 02:11 PM   #20
MARTINSR
MARTINSR's Avatar
too cool
I was a rat rodder when rat rodding wasn't cool.
High school parking lot 1977.
Brian
1948 Chevy pickup
Old 09-09-2015, 02:13 PM   #21
MARTINSR
MARTINSR's Avatar
too cool
Notice the white Pinto fender where I cut the metal from to lengthen the roof. And the Black&Decker electric 1/4" drill with the grinder adapter on it.
Brian
1948 Chevy pickup
Old 09-09-2015, 02:35 PM   #22
MARTINSR
MARTINSR's Avatar
Sorry for the hijack.
Brian
1948 Chevy pickup
Old 09-10-2015, 01:53 PM   #23
_Ogre
_Ogre's Avatar
all relevant to this thread martinsr
and very cool
Old 09-10-2015, 05:35 PM   #24
mr48chev
mr48chev's Avatar
It's good info for both guys who are wanting to chop a truck and for guys who might want to stretch the cab for more leg room. As I said earlier I saved several of those photos for reference Referring to and studying good build tips helps all of us build a better truck. On sectioning the truck cab the photos show drilling out the spot welds and slipping the top back down over the firewall and cowl sides may save untold hours for me over just cutting through the middle of the cowl and firewall and welding it back.
