Old 09-10-2015, 03:12 PM   #1
tommy217xxx
tommy217xxx's Avatar
Sm 465 question
Hey everyone, I have a 76 gmc with a sm 465 trans and it shifts pretty rough. When I down shift into 2nd it usually grinds. It's kinda hard to find the gears when normally driving.
If I replace the shifter with it make the shifting smoother? Is it possible to replace the shifter and what does everyone like? The trans is a top load trans and the truck has a removable trans tunnel.
TJ
76 gmc 1500 swb patina finish
Dropped 4/5, 350/4 speed
80 Chevy c10 lwb
305/350
tommy217xxx is offline   Reply With Quote
Old 09-10-2015, 03:55 PM   #2
77 Big 10
77 Big 10's Avatar
Re: Sm 465 question
The SM465 is a top loaded, top shifting truck style transmission. The shifter, for lack of a better term is a "stick" that drops into the top of the trans. You can replace the stick if the bottom is worn and no longer is doing it's job. Hard to find gears can be worn internal shifting parts. The grinding can be clutch out of adjustment, or worn synchro teeth (dog ears). Try double clutching and slide it into gear.
Paul
77 Big 10 is offline   Reply With Quote
Old 09-10-2015, 06:39 PM   #3
Keith Seymore
Keith Seymore's Avatar
Re: Sm 465 question
Agree.
Said differently the shifter is basically a giant screwdriver stuck in the top of the trans. Replacing it probably will not make any difference.
K
Chevrolet Flint Assembly
1979-1986
1986 - 2019
Old 09-10-2015, 08:04 PM   #4
tucsonjwt
Re: Sm 465 question
x2 on Keith's shifter info. I just had the clutch replaced and the input shaft re-sleeved on my SM465. I had hard shifting and it is better now. Unless this problem just came up, you know that grannys are not smooth shifters. The mechanics working on my truck said they rarely rebuild SM465s - usually the internals are in good shape. Aside from the worn input shaft, the one on my 83 was OK. With a bad clutch, you should hear some rattling and chattering when you shift.
tucsonjwt is offline   Reply With Quote
Old 09-10-2015, 08:13 PM   #5
tommy217xxx
Re: Sm 465 question
On thing that I've noticed is the clutch pedal seems be walking up. The pedal starts to hum in 3rd and 4th gear. The first time I heard it I thought it was the dash vibrating. If I give it a tap it goes back down and stops vibrating.
TJ
80 Chevy c10 lwb
305/350
Old 09-11-2015, 12:49 AM   #6
franken
Re: Sm 465 question
See the 3 holes in the shifter tower in the pic? I seem to recall the shifter is held in by a roll pin through there. There's an article somewhere about fixing a wallowed out hole in the shifter. It may help with finding but not grinding.
https://www.google.com/search?q=+sm4...ter&gws_rd=ssl
