Old 09-12-2015, 09:32 PM   #1
buds56
buds56's Avatar
5.3 ring and bearing job
I got a cheap 5.3 for my 61 project that had a small ticking noise which showed upon pulling the valley cover a bad roller lifter and a cam lobe wearing. this engine ran fine at least 40lbs of oil pressure, no smoke, no coolant use, 150k miles.
I bought a gasket set, head bolts, stock cam, lifters.
Pulling the cam out today brought out a damaged middle cam bearing.
So the engine needs to come apart for new cam bearings and a thorough cleaning, cylinders look like new.
Can I just "ring and bearing" it?
Using the pistons and rods over again, stock rebuild.
I would just get a wrecking yard engine but I already bought some parts.
Thanks,Bud
buds56 is offline   Reply With Quote
Old 09-13-2015, 03:29 AM   #2
BR3W CITY
meowMEOWmeowMEOW
BR3W CITY's Avatar
Re: 5.3 ring and bearing job
Get a set of ARP con-rod bolts if the pans going to be off anyway. Yes they cost a bit more, but since you already have 150k on the stock ones, it won't hurt..plus its great insurance if (when) you decide to turn up the wick a bit and not fear a failure at higher rpm.
'66 Short Step / SD Tuned / Big Cam LQ4 / Backhalfed /Built 4l80e / #REBUILDEVERYTHING
MY BUILD THE H8RDCPTR //\\ MY YOUTUBE CHANNEL REV J HD
BR3W CITY is offline   Reply With Quote
