09-10-2015, 09:14 PM | #1 |
New to the board, ? on 79 gauges
Buying a 79 swb and the speedometer isn't working. What are a few things to check first? I worked at a hotrod shop for years but I was the body and paint guy. Gauges and wiring are foreign to me. Thanks and I love the board
09-10-2015, 09:48 PM | #2 |
Re: New to the board, ? on 79 gauges
Mine stopped working and it was the cable. Got a new one from LMC truck
Paul |
09-10-2015, 09:51 PM | #3 |
Thanks man!
09-14-2015, 04:10 PM | #4 |
78K & 79C Jimmys
do you have cruise?
does it go to the tranny? or is it a K to the transfer case? some have the cruise control mounted under the hood,maybe the cables are loose or stuck
John 1978 GMCJimmy4X4-350/203 1979 GMCJimmy4X2-305/350 |
09-14-2015, 05:57 PM | #5 | |
I was going to mention if it has factory cruise it goes from transmission to driver side inner fender to a "box" then to the speedo. So technically two cables, a divider box and of course the speedo gear itself in transmission. This is for 2wd. I have no idea how 4wd is setup. Good luck, CT |
