Old 09-10-2015, 09:53 AM   #1
jmillsUT28
1972 Blazer rear shakes when braking
Working out a few more bugs in the blazer that I just bought. One is when I start to brake there's a rattle/vibration shaking in the rear. The shocks do look out so that might be a problem. What else could be the problem? Anyway to test it to see what is worn out?
jmillsUT28 is offline   Reply With Quote
Old 09-10-2015, 10:30 AM   #2
pat english
pat english's Avatar
Re: 1972 Blazer rear shakes when braking
Your sway bar bushing could be worn out.The one in my burb was worn and the rear was wobbly.
pat english is offline   Reply With Quote
Old 09-10-2015, 01:56 PM   #3
cleszkie
cleszkie's Avatar
I would pull the drums and look for things such as broken shoe retainng pins, broken shoe pivot stud, damaged shoes, broken/missing springs, etc. Any of these will result in loose parts and/or erratic braking. Also check that the brake shoes have been installed in the proper location. Each pair of shoes has one with a long lining and one with a shorter lining. I can't recall which one is supposed to go in the front or rear position, but it makes a difference. Do it wrong and the brakes will be "grabby".
cleszkie is offline   Reply With Quote
Old 09-11-2015, 07:11 PM   #4
Ta12sec
Vibration when braking is usually in the brakes. Make sure your wheels are tight, if they are and u feel the vibration in the rear I would start with doing brakes in the rear.
Ta12sec is offline   Reply With Quote
Old 09-12-2015, 10:47 PM   #5
ClassicStyle
ClassicStyle's Avatar
Drums are warped.
ClassicStyle is offline   Reply With Quote
Old 09-16-2015, 09:44 AM   #6
Mr Banshee
Agree with Classicstyle, when braking if shaking occurs or a pulsating pedal is usually the cause of warped or to much run out in the rotors and drums.
Mr Banshee is offline   Reply With Quote
Old 09-16-2015, 10:56 AM   #7
Mike C
Mike C's Avatar
Shocks can and will contribute to this as can loose u-bolts. But drums are most likey suspect.
44 Willys MB
52 M38A1
64 Corvette Coupe
68 Camaro 'vert LT1 & TH700
69 Z/28 355 12.6's @110
72 Jimmy 4WD 4spd 4" & 35's
02 GMC 2500HD 4x4 Duramax
Mike C is online now   Reply With Quote
