Closed Thread
Old 09-15-2015, 11:29 PM   #1601
RKS0069
RKS0069's Avatar
Re: What did you do to your truck today part III
Made some progress over the weekend. Sorry about the sideways pictures, any tips to rotating them? They were not sideways on my computer.
http://67-72chevytrucks.com/vboard/s...d.php?t=675881
1972 C-10 SWB
1962 3/4 ton LWB
2011 GMC Sierra LML Z71 crewcab shortbed
RKS0069 is offline
Old 09-16-2015, 07:34 AM   #1602
Marv D
Registered Truck Offender
Marv D's Avatar
Originally Posted by Turtleman View Post
Your selling the motor??
No T-man,, the whole truck once it's back to a more street friendly version (unless someone were to make me an offer for it with the 660HP motor and all,, it's going to eventually)
Still playin with trucks, even at my age!
When you're dead, it's only a problem for the people around you, because you don't know you're dead.
.....It's kinda the same when your STUPID.
I just did my taxes and reviewed my SS statement. Thanks to the current administration it looks like I will only have to work till noon on the day of my funeral.
Marv D is offline
Old 09-16-2015, 05:03 PM   #1603
OldChevy61
OldChevy61's Avatar
Been trying to finish blasting my frame,but keep blowing holes in the ball valve on the blaster hose. Already been through 4 valves in two bags of media. Ordered some stainless steel one today,so maybe next week I will have some new pics. Finally cooling off enough to get motivated. Only problem with that is now its Deer season.lol
OldChevy61 is offline
Old 09-16-2015, 05:51 PM   #1604
Lugnutz65
Lugnutz65's Avatar
Yeah, I blew a hole in the valve for the hand control. It needs to be all the way open. If media flows around any corners while under pressure, it will just eat away at it. Keep at it and you will be motivated by the progress. It's addictive.
My 65 C10 build: www.lugnutz65chevystepside.weebly.com
Want to know more about T5 transmissions? My website has a T5 Info Page and a Step by Step T5 rebuild.
Lugnutz65 is offline
Old 09-16-2015, 06:08 PM   #1605
OldChevy61
OldChevy61's Avatar
Oh I love the progress,just not the heat,lol
Old 09-16-2015, 06:46 PM   #1606
sambrutay
sambrutay's Avatar
headlights quit on me Saturday night after leaving a local cruise. So I figured I had better figure it out with Goodguys coming up this weekend in Bowling Green.
Narrowed the problem down to the dimmer switch. Had some high resistance in some terminals. So cleaned them up and did a little solder job. Put it back together and still no luck.
I would get power when I pushed down on the switch so I took it back apart. I filled the dimples in the spinner wheel with solder and now all is well.
I guess it had worn and created enough clearance that it would not make good contact.
Bruce
1964 C10 SWB #Junk
1979 C10 utility #cargopants (sold)
1971 GMC Sprint (sold)
1974 GMC Grande Sierra (sold)
sambrutay is offline
Old 09-16-2015, 07:14 PM   #1607
Lugnutz65
Lugnutz65's Avatar
Holy cow! Nice work. I'd have just given up and bought a new one. Very cool that you know how to fix that stuff!
Old 09-16-2015, 07:33 PM   #1608
sambrutay
sambrutay's Avatar
Thanks, Probably should have bought a new one, but did not want china junk.
Bruce
1964 C10 SWB #Junk
Old 09-17-2015, 10:01 AM   #1609
robber grin
RKS NICE work on the PS adapter.
Bruce, I admire your tenacity - fix'n what you got - love it. I just bought a dimmer from NAPA and we'll see how long it lasts.
Last night I finished wiring and shrinking all my connections in the home-made harness going aft for lighting and fuel sender. Turned out good. Added ground wires in several places too.
Blazer tank filler and vent hose added. Tightened bed mounting bolts and touched up some paint underneath.
I'm trying to get it back on the floor so I'm buttoning up everything I can think of underneath!
So I installed and ran the speedometer cable my buddy gave me...
now to bleed the brakes and sit it back on the tires.
robber grin is offline
Old 09-18-2015, 06:09 AM   #1610
robber grin
Didn't get the brakes bled but I plinked a bit anyway
Turned the re-pop Stock gas tank cover into a back panel, finished my Civic door seals, rebuilt my instrument panel, modified my glove box door.
Old 09-18-2015, 08:36 PM   #1611
robber grin
Still have yet to bleed the brakes, but I do have doors that close and latch now.
Old 09-19-2015, 06:32 PM   #1612
Grizz1963
Grizz1963's Avatar
Loads of stuff, captured in my build thread.
However, also removed the old steering column.....
And tried out the "new" one.
Understood to be from a Chevy Day van of unknown vintage. Possibly 80/90's
I was wondering if anyone knows what it's cable operated section is for?
If you turn the ignition key beack and push it in after turning it to the "off" position, it activates a cable in there, but then you cannot remove the ignition key.
This component is in the way where I need to fit the column,so needs to be removed, but I have no idea what it's purpose is.
Advice and help appreciated.
Thanks as always.
MY BUILD LINK: http://67-72chevytrucks.com/vboard/s...585901]Redneck Express - 1966 C10 Short Fleetside
MY USA ROADTRIPS http://forum.retro-rides.org/thread/...2018-humdinger
IF YOU CAN'T FIX IT WITH A HAMMER, YOU'VE GOT AN ELECTRICAL PROBLEM MATE.
Grizz1963 is offline
Old 09-19-2015, 06:47 PM   #1613
BR3W CITY
meowMEOWmeowMEOW
BR3W CITY's Avatar
I wiped the '66 down with some detailing spray....
...then went and beat on a Ferrari 360 Spider for a while
'66 Short Step / SD Tuned / Big Cam LQ4 / Backhalfed /Built 4l80e / #REBUILDEVERYTHING
MY BUILD THE H8RDCPTR //\\ MY YOUTUBE CHANNEL REV J HD
BR3W CITY is offline
Old 09-19-2015, 08:51 PM   #1614
vince1
I didn't unload my spare 10si alternator from the vacation car so it came along for the ride to Seattle, BC's sunshine coast, back to Seattle and finally home to Calgary again. This upsets me that I didn't have a place for it so on to the 66 C10 today it went. It only took about an hour and a half including the conversion from externally regulated. The bearings in the old one feel a bit rough so that's a good excuse to drop it off for recycling at a local alternator shop.
vince1 is offline
Old 09-20-2015, 01:50 AM   #1615
WOLFMANmike
WOLFMANmike's Avatar
I rebuilt my first carburetor but by the time it was done I was out of day light . So never got to test it and see if I did it right or not lol
WOLFMANmike is offline
Old 09-20-2015, 02:04 AM   #1616
mattbert56
mattbert56's Avatar
Since switching jobs. I now work in the town I live in so I took my new daily driver to work so pumped to be driving it consistently now.
Well that didn't go as planned.
1965 k20 buikd thread: http://67-72chevytrucks.com/vboard/s...=628346&page=6
mattbert56 is offline
Old 09-21-2015, 01:24 AM   #1617
RKS0069
RKS0069's Avatar
Officially bolted the '82 C30 front suspension into my '62 temporarily. Installed Hydro Boost onto bracket. Mocked up steering shaft. Stared at rear of frame for an hour contemplating brackets for new fuel tanks. I guess you could say I now have power steering and disk brakes!!
1972 C-10 SWB
1962 3/4 ton LWB
RKS0069 is offline
Old 09-21-2015, 06:59 AM   #1618
Paul Y
Plus
And one of these
Equals
But this
Highlights the need for these
And possibly
As there is probably another 20-30 loads of this.
One day I will get round to updating what I have been doing and why there is a rather large ‘red rash’ on Woody’s flank.
But until then…
P.
Paul Y is offline
Old 09-21-2015, 02:37 PM   #1619
Northwest Outlaw
Northwest Outlaw's Avatar
Paul Y wins. Truck, chopping wood, beer can never be beat.
All I did was load a small block and th400 into my s10 and brought them home. Small block needs to be rebuilt, so that will be my life for awhile.
1961 Chevy Apache "BoomStick"
-First build, lots of plans, little experience. What's the worst that could happen?
http://67-72chevytrucks.com/vboard/s...d.php?t=694506
Northwest Outlaw is offline
Old 09-21-2015, 08:07 PM   #1620
dougf
dougf's Avatar
Almost done with the inside of a bedside, gotta finish welding up the outside Sean from the long to short conversion, the smithing about what coating it's going to get. Rust run is on it now to prevent rust u till I figure out if it's getting por15 and bedliner or...
dougf is offline
Old 09-22-2015, 12:39 PM   #1621
RKS0069
RKS0069's Avatar
Dry fitting the tanks.
1972 C-10 SWB
1962 3/4 ton LWB
RKS0069 is offline
Old 09-22-2015, 06:04 PM   #1622
I likr those tanks...Are they the standard Blazer style tanks?
Palf70Step is offline
Old 09-22-2015, 06:11 PM   #1623
mattbert56
mattbert56's Avatar
Originally Posted by Paul Y View Post
Plus
And one of these
Equals
But this
And possibly
But until then…
P.
Possibly one of the best posts iv seen on this forum in a while. Well don't amight
Old 09-22-2015, 06:24 PM   #1624
Paul Y
Thank you Matt, appreciated.
P.
Paul Y is offline
Old 09-22-2015, 11:17 PM   #1625
donthekawguy
donthekawguy's Avatar
Got the motor and trans out today. Good thing my boys came to help out. We had a tough time pulling the hoist back into the garage through the gravel. lol
66 shorty
donthekawguy is offline
Closed Thread
