Go Back   The 1947 - Present Chevrolet & GMC Truck Message Board Network > General Truck Forums > Tools, Shops and Shop Safety
Old 09-09-2015, 02:54 PM   #1
Racer2172
Parts cleaner tank solvent
So what is everyone using in their parts cleaner tank as a solvent. I tried the HF mix with water type, did not like the result. So what would you guys recommend for a cleaning solvent in the tank.
65 C-10 Times gone by(Sons truck)http://67-72chevytrucks.com/vboard/s...92#post6164692
70 C-30 Tow truck AKA Highlighter
02 Silverado 2500 HD CUCVII Tow Rig/DD
1968 C10 Project Quarantine http://67-72chevytrucks.com/vboard/s...d.php?t=804800
1980 Buick Regal Dirt Stock car
Racer2172 is offline   Reply With Quote
Old 09-09-2015, 04:52 PM   #2
cdowns
cdowns's Avatar
Re: Parts cleaner tank solvent
I've used old school kerosene for the past 50years or more
Old 09-09-2015, 05:11 PM   #3
Blown06
Blown06's Avatar
I like the Graymills Super Agitene, it's pricey but it works well and isn't too hard on my hands. Varsol is another that I used to get at the parts store, I would give it a good second and Kerosene if those aren't available.
Here's link to the Graymills stuff. https://www.northernsafety.com/Produ...urpose-Solvent
Me: Jarrod
My project: http://www.67-72chevytrucks.com/vboa...d.php?t=646563
Blown06 is offline   Reply With Quote
Old 09-09-2015, 05:53 PM   #4
PeterHall
We bought this and it seems to work pretty well.
http://www.amazon.com/gp/product/B000EANNDM?psc=1&... http://www.amazon.com/gp/product/B000EANNDM?psc=1&...
PeterHall is offline   Reply With Quote
Old 09-10-2015, 02:03 PM   #5
_Ogre
_Ogre's Avatar
most washer tank fluids are 409 based or so they smell similar
i prefer mineral spirits over diesel only for the smell
shop air compressor timer
Old 09-10-2015, 02:24 PM   #6
tinydb84
tinydb84's Avatar
The marine clean from POR15 works wonders for me. Use gloves as it will suck all the oil out of your skin.
David
Instagram: myfabguy
Old 09-11-2015, 08:23 AM   #7
Willie Makeit
Willie Makeit's Avatar
mineral spirits
Willie Makeit is offline   Reply With Quote
Old 09-11-2015, 09:24 AM   #8
dfwright
dfwright's Avatar
I use marine clean also. Remarkable stuff, and x2 on the gloves. This stuff will dry out your hands horribly otherwise.
1972 C10 LWB, 350/350
Deconstruction began 5/2009, mostly completed restoration, 5/2017
dfwright is offline   Reply With Quote
Old 09-11-2015, 11:18 AM   #9
cg285
mineral spirits. with a fresh fill dump a qt of atf in it - easier on the hands unless you of the younger generation and wear those hand condoms
cg285 is offline   Reply With Quote
Old 09-11-2015, 04:10 PM   #10
_Ogre
_Ogre's Avatar
the trick to using mineral spirits is...
leave it sit for a couple of weeks if you can, all the junk and oil will go to the bottom
carefully pour off the top and you have ''new'' mineral spirits
Old 09-12-2015, 11:22 AM   #11
pwdcougar
pwdcougar's Avatar
A friend with a transmission shop uses mineral spirits. If it is good for all those little bits in an automatic transmission it is good enough for me.
Paul
"You know that little thing in your head that keeps you from saying things you shouldn't? Yeah well, I don't have one of those"
1969 Mercury Cougar Standard 4 speed
1969 Mercury Cougar XR7 convertible
1970 4WD Chevrolet Suburban
1997 4WD Chevrolet Silverado Extended Cab Short Bed (purchased new January 1997)
pwdcougar is offline   Reply With Quote
Old 09-12-2015, 02:15 PM   #12
bpatrol
i've used mineral spirits in mine with good results but add atf and its more effective.
bpatrol is offline   Reply With Quote
Old 09-16-2015, 06:18 PM   #13
BLAZERMAN
Currently Blazerless
BLAZERMAN's Avatar
I use mineral spirits as well, stuff lasts forever and is great at cutting grease. I use an older Safety Clean parts washer that sits in a 15 gallon drum, after 20 years of service the drum developed a leak last month...I didn't think I was ever going to find another 15 gallon steel drum to replace it!
1972 C/30 133" W.B. C&C
1970 GMC 3500 157" W.B. single wheel C&C
BLAZERMAN is offline   Reply With Quote
