![]() Join Date: Apr 2011
Gauging interest in 1972 extreme bend tow hooks
I just bought a set of genuine GM 1972 extreme bend tow hooks at $600.00 for the pair. I know there is a market for these and I'm not the only one out here that wants them. That being said, I've reached out to a local foundry and they've agreed to make these for me. Now obviously, they will be copies and non GM but I'm looking at setting the price at $300.00/pair. That's half what I paid. I can't go any lower than that and make it worth my time.
As far as I know, no one is making these at this time and I'd like to be able to offer these to you guys at a more affordable price. I'm looking at having 50 poured. That's 25 pair. If interest in these is extremely high, I'll be able to get the price down even lower. Thanks!
JASON 1972 Cheyenne SWB (402/400, tilt) 1972 GMC Sierra LWB (402/400, tach, tilt) |
![]() Join Date: Apr 2005
Re: Gauging interest in 1972 extreme bend tow hooks
Are they forged? If so, what alloy?
1978 Dodge Omni |
![]() Join Date: Apr 2006
I would be interested depending on the material.
Kirk 72 Blazer CST 4wd highlander 66 Nova |
Depends on material used and if they are forged.
Ray |
Sounds cast to me by the description.
![]() Join Date: Sep 2007
I wonder if these are going to have a high nickel content. Is the raw material from the U.S. or imported material?
1971 Cheyenne Super C-20 402 4 speed 1970 El Camino L-48 350 1999 Chevy Z-71 Extended Cab 4x4 2000 Tahoe Z-71 2004 Monte Carlo S.S. Supercharged Dale Earnhardt Intimidator 1970 Chevelle, Malibu Sport Coupe 2007 Harley-Davidson FLHX Street Glide |
I'm working on getting the answers guys. I've got a call into the foundry. As soon as he gets back with me I'll tell you what the process is going to be and what the material is.
![]() Join Date: Apr 2015
the 72 extreme bend hooks are rare and yes very desirable and spendy. I think they were a 6 month run and one year only. more people would be into the 69-72 regular hooks seems like and might possibly sell like hotcakes. great idea and please keep us posted.
Here's the requested info guys...
As discussed we are a Gray and Ductile cast iron foundry and we offer several grades of each. For your application with the tow hooks, I would recommend a standard 65-45-12 Ductile iron. I have included the mechanical properties below.
![]() Join Date: Mar 2012
in line for a pair
![]() Join Date: Jan 2002
would these fit other years ? and 2 wheel drive ?thanks
Pretty sure these would work for any year 4x4. I need to look at one of my 2 wheel drives and see if the frame is drilled for the hooks. I can't remember for sure. I think this is a go guys. I'm going to put the order in next week. I'll let you all know when I have them.
Posted via Mobile Device |
Are you sure you want to accept the potential liability for these?
1970 Short Wide 5.3 4L60E BlackBear tune 3:73 gears, Boyd's Tank 2.5 / 4 drop 5 lug disc brakes Vintage Air 18x8 Ridlers 255/55 frt. 18x9.5 275/60 rear |
#15 |
If the foundry will guarantee me that the grade 8 hardware will fail before the hooks, where's the liability exactly?
#16 |
wtf, mine will b for show. how many of us are going to put them to the test??? get real c3vette4spd pm me when ya figure it out. 2 thumbs up
#17 |
Just pointing out a potential issue. Structural items such as these go through extensive engineering and testing for not only the design geometry but the material as well. Substituting a different material won't give the same results. Grade 8 fasteners have 150,000 psi min. tensile strength, the material you are specifying is 65,000 psi. This does not necessarily mean the bolts won't fail first because it also depends on cross section of the material and how it is loaded, but it would have to be tested under controlled conditions to be sure.
Car manufacturers sometime still don't get it right and people are injured or killed but they have billions of dollars and high priced lawyers on their side. I think its great you want to help out the community with a scarce item such a this, I just wanted to bring it to your attention. I wouldn't be able to sleep at night with a don't worry its only going to be used for show mentality. There are still lots of people using these trucks to work with. Good Luck
#18 |
Ever seen all the 10 dollar pot metal "tow hooks" the ricer crowd uses? I'm going to say these will be fine.
#19 |
Moderator
![]() Join Date: May 2007
If I had a show truck I would pay $300 for "factory correct" tow hooks and make sure they didn't get scratched.
If I had a work truck I would buy $20 generic hooks that I see on work trucks and in parts catalogs all the time and use the crap out of them.
1972 C/10 Cheyenne Super SWB. Restored, loaded, slammed. 1968 C/10 50th Anniversary LWB. Unrestored, stock, daily driver/work truck. RIP ElJay RIP 67ChevyRedneck RIP Grumpy Old Man |
#20 |
Born Psycho
![]() Join Date: Feb 2001
sounds like a great idea to me since the price has gone crazy again. i have the extreme bend hooks on both my trucks and i've used them many times, if they get scratched i repaint them. as for frames being punched for the bolts, not all frames have the holes, my 72 super 4x4 has holes, my 69 suburban 4x4 did not, one of my blazers had them and the other did not. i'm not sure why some had holes and others did not, maybe depended on where the frame was built. sort of like some 4x4 frames had a factory steering box brace and some did not.
jerry moss 72 cheyenne super K20- tilt,tach,vacuum,speedwarning,buckets,shoulder belts,am/fm,tow hooks,bumper guards,toolbox,aux. fuel tank,posi front and rear,plus other goodies!!! SOLD 69 suburban K20-tilt,tach,vacuum,speedwarning,buckets,shoulder belts,am/fm,4 inch all spring lift,4 speed, 14 bolt full floater, dana 44 HD,warn winch,posi front and rear,tow hooks,plus other goodies. 73/80 chevy/gmc K20 SB400,turbo 400,205,tilt,a-c,gas hog. 77 K/5 cheyenne blazer-daily driver/beater. SON HAS IT NOW BRENTWOOD,CALIFORNIA |
#21 |
Subscribed
#22 |
Kennuck YOU ARE CORRECT
#23 |
Moderator
![]() ![]() Join Date: Aug 2011
Since you will be buying these and using them at your own risk, the liability will be with you the buyer. Do you ask what liability AMD has on their products? and their a large company. Some guy is trying to help the community out and you (some internet lawyer) try and stop him in his tracks. Thanks.
Use em at your own risk. If you buy them and beat your wife with them over the head is he liable?
Master Chief, US Navy, Retired 1964 C10 Step-side Short Bed - In Progress 2009 2500HD Duramax LTZ 1948 GMC Panel 1956 Big Window Stepside 1953 5 Window Chevy Stepside 1932 Coupe New Seat Foam for Bench Seats? Last edited by The Rocknrod; 09-25-2015 at 08:14 AM. |
#24 |
![]() Join Date: May 2001
Subscribed
72 3/4t Custom Deluxe 402/auto 66k Original paint 71 3/4t 4x4 Custom Deluxe 10k original miles Original paint 71 3/4t Cheyenne 402 70k original paint 72 3/4t 4x4 Custom deluxe 72 3/4t 4x4 Custom deluxe 91k original paint 72 Cheyenne/30 Dually 69 Camaro SS396 4-speed 13 GMC 2500HD Duramax I bought new 05 Jeep Wrangler "Willys Edition" 12k miles (I bought new) 85 3/4 ton 4x4 Scottsdale 33k miles original paint 86 1 ton 4x4 SRW Silverado 454 restored 80 1 ton 4x4 SRW Silverado 9,434 original miles!! original paint 95 GMC 1 ton dually 4x4 my dad bought new 95 GMC 3/4 ton 4x4, regular cab 454, 31k original miles 2002 2500HD 4x4 regular cab 6.0L 67k miles 2002 2500HD 4x4 regular cab 8.1L 28k miles 2003 GMC 2500HD 4x4 regular cab Diesel 93k miles 67-72 Parts for sale |
#25 |
All about them K’s
![]() Join Date: Jun 2014
I'd possibly be interested as well.
Tyler '57 3100 http://67-72chevytrucks.com/vboard/s...d.php?t=813888 '72 K20 Cheyenne http://67-72chevytrucks.com/vboard/s...d.php?t=662879 ‘69 K10 SWB http://67-72chevytrucks.com/vboard/s...d.php?t=805206 '98 Silverado LT K2500HD ECLB Vortec 454/4l80E: 6" lift 315/75/16's ‘87 IROC-Z all original 50K mile survivor TPI 305 IROC Blue ‘10 Camaro 2SS/RS Aqua Blue Metallic #93 -version 2.0 ![]() |
Tags |
extreme bend tow hooks |
