09-06-2015, 01:29 AM | #1 |
Picture of OEM bracket for coolant overflow?
1971 Chevy
I believe the original(s) mounts to the core support. I've seen two bracket types that are claimed original. On one bracket, the belt holding the bottle slopes downward. The other bracket is square with the bottle. I'm certain the one that slopes downward is original, but haven't seen the back portion that mounts to the core support. Anyone have a picture? Feel free to post the square one as well.
Tony 71 Custom Deluxe, SWB, 2WD, 402, A/C. I developed an assembly kit for restoring the (a) truck from the ground up. My build thread, and more on the assembly kit https://67-72chevytrucks.com/vboard/...d.php?t=730025 Last edited by 71CHEVYSHORTBED402; 09-17-2015 at 12:01 AM. |
09-06-2015, 04:23 PM | #2 |
Re: Picture of OEM bracket for coolant overflow?
Rare like hen's teeth?
Tony 71 Custom Deluxe, SWB, 2WD, 402, A/C. I developed an assembly kit for restoring the (a) truck from the ground up. My build thread, and more on the assembly kit https://67-72chevytrucks.com/vboard/...d.php?t=730025 |
09-06-2015, 04:39 PM | #3 |
I tried taking a pic of my bracket, but because it's mounted I can't get a good picture. Are you looking for the angled bottom bracket piece that mimics the bottom angle of the bottle?
09-06-2015, 07:25 PM | #4 | |
09-07-2015, 06:32 PM | #5 |
"still" curious.
09-07-2015, 08:19 PM | #6 |
There's a bottle or just a bracket for a hose?
My '72 Corvette is original (except paint) and there is no overflow bottle.
09-07-2015, 10:01 PM | #7 | |
Not aware of just a hose bracket, but I suppose there would be. There is a hose bracket for the bottle and bracket. It mounts to the core support under the shroud. See post 20 here: http://67-72chevytrucks.com/vboard/s...d.php?t=546610
09-07-2015, 11:24 PM | #8 |
I'll get you a pic or two of mine tomorrow
United States Marine Corps 2000-2011 Iraq and Afghanistan veteran Just living life now and enjoying it and my wife, daughter and son |
09-08-2015, 09:43 AM | #9 |
This is the one I'm running on mine currently. I'll try to get a better pic of the backside of the bracket. |
09-09-2015, 01:05 PM | #10 |
I think I have an original bottle and bracket on my shelf if you looking for one.
09-09-2015, 11:43 PM | #11 |
If the bottle is like new and the metal good, definitely.
09-16-2015, 10:37 PM | #12 | |
By chance does the back of your bracket like this? http://www.ebay.com/itm/GM-15996772-...-/111677506557 Or like the one here, post 14? http://67-72chevytrucks.com/vboard/s...d.php?t=546610
09-16-2015, 10:52 PM | #13 |
The bottom of the bracket is angled. The one on ebay looks square to the bottle. or maybe I'm just looking at it weird. I hope this helps. My coolant hose is too snug too lift the bottle out of the bracket so I could get a better look.
09-16-2015, 11:06 PM | #14 |
Moderator
The bottom bracket is very easy to bend up or down by hand.
1972 C/10 Cheyenne Super SWB. Restored, loaded, slammed. 1968 C/10 50th Anniversary LWB. Unrestored, stock, daily driver/work truck. RIP ElJay RIP 67ChevyRedneck RIP Grumpy Old Man RIP FleetsidePaul |
09-16-2015, 11:45 PM | #15 |
Well, I've seen two claimed originals. One, the bracket is square with the bottle. the other, the bracket is angled. Important to note there are those that came with the truck, others a GM part dealer installed. The bracket with the angle is said to be dealer installed.
Looking at parts books, I'd expect to find the reservoir under category 1.240. There's no mention of a reservoir for these older trucks. Just a hose and clip.............Under 1.240 for a 1991 model, for example, "RESERVOIR, COOL RCVY" is included. Thanks for checking Demi. Wouldn't want you to scratch the bottle anyway.
Tony 71 Custom Deluxe, SWB, 2WD, 402, A/C. I developed an assembly kit for restoring the (a) truck from the ground up. My build thread, and more on the assembly kit https://67-72chevytrucks.com/vboard/...d.php?t=730025 Last edited by 71CHEVYSHORTBED402; 09-17-2015 at 12:19 PM. |
