Old 09-18-2015, 11:00 AM   #1
paulbrgr9999
1970 c20 350 vs Toyota I force 5.7
My tundra 5.7 puts out something like 380 HP, 400 foot lbs of torque.
What would I have to spend to get my 350 in my c20 to match those numbers? Would I have to get a stroker? Would a crate motor with a rv cam get me there?
I've pulled my toy hauler with both trucks. The trailer fully loaded is around 5000lbs. The tundra just flys along up and down hills. The Chevy 350 struggles.
Thank you
paulbrgr9999 is offline   Reply With Quote
Old 09-18-2015, 11:16 AM   #2
Bigdav160
Bigdav160's Avatar
Re: 1970 c20 350 vs Toyota I force 5.7
A small supercharger would do it.
My Classics:
'72 K20 Suburban + '65 Dodge Town Wagon
'72 Corvette Roadster +'67 Corvette Roadster
'73 Z-28 Camaro
'63 Ford SWB Uni Pickup
'50 Ford Coupe
Bigdav160 is offline   Reply With Quote
Old 09-18-2015, 12:07 PM   #3
hugger6933
A vortec replacement motor with a LT4 hot cam and a good intake you will be right there with those numbers. Every magazine rag has done vortec articles or the last 20 years and made stupid numbers without much work. I'm talking vortec as in heads that are 96-99 truck so all the small block stuff will work saving money. It has been proven time and time again that those vortec heads make 40 hp over anything else chevy has done. Jim
hugger6933 is offline   Reply With Quote
Old 09-18-2015, 01:06 PM   #4
leftybass209
leftybass209's Avatar
Well first thing is first, NO you do not need to do a stroker to get that kind of power. It could help achieve that kind of HP later in the RPM band though.
Looking at crate engines, your options are slim to make that kind of power while keeping it everyday-driver capable.
The top Edelbrock package utilizing a GM Goodwrench 350 as the starting point, makes 363HP and 405ft-lbs of torque, and comes in at $6195.00 base price. That engine utilizes a roller cam, aluminum heads, and either a 750cfm carb, or dual quads.
That engine could be duplicated for a little under half their price if you do the work, sans warranty.
Of course there's dozens of ways to make that kind of power, and prices all over the map to match. Using Huggers suggestion of Vortec heads (Great idea!) The Goodwrench quest article from the early 2000's has a GM Crate with Vortec heads making 384hp, 401ft-lbs torque. The corvette LT-1 heads make slightly less HP/TQ but also shave weight.
leftybass209 is offline   Reply With Quote
Old 09-18-2015, 01:46 PM   #5
paulbrgr9999
Any opinions on this:
http://www.westcoastengines.com/#!bu...for-sale/c10i4
Old 09-18-2015, 02:12 PM   #6
leftybass209
yeah, I've got an opinion about that!
They state $300 core, $298 dyno session which they don't state mandatory or optional, and shipping starting at $150.
I prefer clear-cut pricing and no bs. So far, they have a $748 dollars in charges before you even pick a motor. Not to mention it's not clear of any charges for getting the core back to them, or if they'll accept your core to refund you that $300.
They name drop some brands and types like hypereutectic and melling but have no part numbers or additional information. They do however, show that they use parts store brand (pioneer) flywheel, balancer, rocker arms and rod bolts.
I'm not bagging on them, but I'd sure call them and find out what exactly is going into my engine.
Old 09-18-2015, 02:33 PM   #7
michael bustamante
michael bustamante's Avatar
for the vortec heads.... does any body have cast # of what to look for? will they work on a '77 4 bolt main?
1967custom
michael bustamante is offline   Reply With Quote
Old 09-18-2015, 03:37 PM   #8
leftybass209
I don't have the casting # off hand. You can Google it.
Yes they'll work on any sbc, but the manifold needs to be changed to accommodate the revised mounting. (The bolts run straight down instead of angled)
They're about 300 bucks each, or whatever boneyard prices you have for a used set. They have a sawtooth pattern where the double hump castings are located. First year was 96 I think.
Old 09-18-2015, 03:48 PM   #9
michael bustamante
ok the double triangles?
1967custom
Old 09-18-2015, 04:21 PM   #10
leftybass209
This was the info I pulled for the casting number, as per Super Chevy,
"Look for casting number 12558062, but avoid casting number 10239906, which has a modified exhaust seat and loses 20 percent of its flow at 0.120-inch lift."
The casting will have triple triangles, and look like the under bite of a classic carved pumpkin, to use an upcoming festive analogy. It's located between two accessory holes.
Old 09-18-2015, 06:24 PM   #11
Lattimer
Lattimer's Avatar
Thank you
I have a Vortec crate motor in my Chevy. It engine dyno'd at 382 HP and 402 ft-lbs. Thats with a 600cfm 4-barrel and long tube headers.
I also have owned several Tundra's. Stock rating is 381 hp, 401 ft-lbs. Current one I just got and had the supercharger installed. 504 HP and 550 ft-lbs rated at the crank.
The Chevy used to feel like a hot rod with the huge weight difference. Now it feels slow.....
Shawn
1970 Chevy C-10 SWB, 350, TKO 600 5 speed
My build http://67-72chevytrucks.com/vboard/s...d.php?t=559881
Lattimer is offline   Reply With Quote
Old 09-18-2015, 06:33 PM   #12
summitflier
summitflier's Avatar
VVT and Throttle body injection is a great thing.
Most of the newer LS's, Gen 3 Hemi's, and Coyote engines have this also.
The good ole 350 is 50 years old. Not many tundra's or Toyota V8s from that era.
But the ole 350 has a few tricks also.
http://www.chevrolet.com/performance...-burn-385.html
http://www.chevrolet.com/performance...t-350-400.html
Not bad for a 50 year old design... no superchargers or turbos required.
Even reasonable streetable.
If you want a newer engine to compete with newer technologies.. check the LS3's.
http://www.chevrolet.com/performance/crate-engines.html
Most are around 430hp, and at least one is rated at 480hp.
I have a smallblock in my truck.. I'd be happy to race your Tundra in it.
68 C10 SSB 383
12 Charger 6.4L
12 Accord 3.5L (Wife's ride)
05 Ram 1500 5.7L
My build thread - http://67-72chevytrucks.com/vboard/s...d.php?t=676545
summitflier is offline   Reply With Quote
Old 09-18-2015, 07:41 PM   #13
Redline novdog
Redline novdog's Avatar
I agree you do not need the stroker crank for those numbers.That is why the small block Chevy was THE MOTOR for building! There are as many builds on the net as there are cubic inches.Good heads,good cam,If you can use a die grinder, you can make a cheap set of heads very good.Bigger valves,good springs.The small block Chevy has not got the status it has because it's a slouch!!
It builds on my intelligence when I make a mistake, Boy am I building on it!
'67 C-10,'70 Nova SS
Redline novdog is offline   Reply With Quote
Old 09-19-2015, 01:30 AM   #14
HeavyD
HeavyD's Avatar
The c20 is a heavy truck and could use the torque that a 383 would provide.
If the 350 is in good shape you can add heads intake exhaust cam usual goodies and will wake right up, but if it needs any shortblock work at all..I would buy a 383 kit and go from there.
"You can take the man out of PA, but you can't take PA out of the man"
HeavyD is offline   Reply With Quote
Old 09-19-2015, 01:32 AM   #15
Z10
Z10's Avatar
ZZ383 Crate
425hp
449 lb-ft torque
That should do it.
http://www.chevrolet.com/performance...ck-zz-383.html
or
ZZ5
400hp
400 lb-ft torque
http://www.summitracing.com/parts/nal-19301294
or a tried and true ZZ4 will get you the torque and close to the HP.
355hp
405 lb-ft torque
http://www.chevrolet.com/performance...k-zz4-350.html
But instead of a carb, perhaps a little FIRST TPI?
1969 RS/SS Z10 Camaro Pace coupe
1972 GMC Short Step buildhttp://67-72chevytrucks.com/vboard/s...=1#post6356218
1979 Mazda RX7
1979 Pontiac Trans Am WS6 & 1979 Pontiac Trans Am 10th Anniversary
1999 Honda Valkyrie
2006 Corvette Z06
2010 BMW 650i
Z10 is offline   Reply With Quote
Old 09-19-2015, 08:46 AM   #16
Redline novdog
I should have added,depends on how much you want to spend,SBC parts are still very affordable and readily available. They will continue to drop off as the LS motors are getting more and more popular.
Old 01-24-2016, 08:07 PM   #17
ironroad9c1
Master Hater
avoid any gm "Crate" engine , they use poorly cast blocks made in Mexico and are assembled there with poor quality control. find a good seasoned core out of a running truck and rebuild it, almost all used vortec heads I've looked at are cracked at the exhaust valve. they are thin castings
1997 C1500 ECSB 4.3/NV3500 8.5 3.42
"This evening, all of you bleeding hearts... why don't just go ahead and hug yourself for the next 20 minutes or so, because there's a really good chance you're gonna be offended".- Captain Owen Honors
ironroad9c1 is offline   Reply With Quote
Old 01-25-2016, 01:15 AM   #18
Z10
Z10's Avatar
I've had a couple of ZZ4 crate motors which have been made in Mexico, and I've had excellent service from them. I also have other friends with ZZ383, Ram Jet 350, and all of them are performing just fine. Also, the LS7,LS9, & LSX are assembled in the US. Do you have specific GM crate motors that you can reference?
I just don't accept the large net you've thrown over all GM crate motors.
1979 Mazda RX7
1999 Honda Valkyrie
2006 Corvette Z06
2010 BMW 650i
Old 01-25-2016, 08:52 AM   #19
ironroad9c1
Master Hater
how old is your engine ? If its over8-10 years old it most likely does not fall under this .
http://www.chevelles.com/forums/13-p...nightmare.html
http://www.hotrodders.com/forum/gm-c...ms-146622.html
http://67-72chevytrucks.com/vboard/s...d.php?t=586595
this was a high dollar race engine , and gm wouldn't even warrenty it.
https://www.youtube.com/watch?v=7jTtviipmHg
I could go on all day,
Old 01-25-2016, 09:48 AM   #20
jjzepplin
jjzepplin's Avatar
Hmm. A c10 with the reliability of a Toyota...Swap? I'ma go find me a wrecked Tundra!
70 swb 4x4 406sbc 700r4 203/205 d60/14blt locker yadda yadda http://67-72chevytrucks.com/vboard/s...88#post6935688 Yeller
72 Blazer 2wd conversion project "No Daggum Money" http://67-72chevytrucks.com/vboard/s...d.php?t=550804 LS1-T56 3.73 LSD super budget build
Blanco-2014 Sierra SWB https://67-72chevytrucks.com/vboard/...d.php?t=810350
jjzepplin is offline   Reply With Quote
Old 01-25-2016, 01:04 PM   #21
ironroad9c1
Master Hater
look around and see how may 20 or even 15 year old toyotas are around.....
Old 01-25-2016, 02:27 PM   #22
Z10
Z10's Avatar
One ZZ4 is 9 years old and the one with the most milage is 3 years old.
1979 Mazda RX7
1999 Honda Valkyrie
2006 Corvette Z06
2010 BMW 650i
Old 01-25-2016, 03:03 PM   #23
CastIron
CastIron's Avatar
The Toyota 5.7 is indeed a powerful engine. And it's pretty reliable too. But I wouldn't swap it into anything else. They are physically huge compared to a small block chevy. Even Toyota V-6s are big, about the same size as a small block.
CastIron is offline   Reply With Quote
Old 01-25-2016, 03:23 PM   #24
GMC Canuck
I would love to have the roll down rear window of the crewmax tundra in my GMC. I think that would be a very cool mod.
If I were to do a toyota swap I'd skip the 3UR-FE (5.7L) and go for the 2JZ (inline 6) My long term plan for my galaxie is a 2JZ swap.
GMC Canuck is offline   Reply With Quote
Old 01-25-2016, 03:36 PM   #25
XwalkerX
the holy grail Toyota swap.
that would make the classic car guys cringe
XwalkerX is offline   Reply With Quote
