Old 09-12-2015, 08:24 PM   #1
LDO
LDO's Avatar
Heat sheild help UPDATED WITH PIC!!
This is on the 290 HP crate motor. The passenger side lower boss where the heat shields would bolt to isn't drilled? There is a boss right next to it that is drilled and threaded but the bracket on the heat shield doesn't reach that hole.
This picture is not of my motor but you can clearly see on the left of the picture there are two threaded bosses. My motor has the raised pad but no hole. It does have the hole to the right which is not used in the pic....
LDO is offline   Reply With Quote
Old 09-12-2015, 11:17 PM   #2
franken
Re: Heat sheild help
What heat shield?
What pics?
What boss?
Old 09-13-2015, 04:55 PM   #3
LDO
LDO's Avatar
woops....
Here is the pic i was talking about. the left shield is bolted to a raised pad that on my motor isn't drilled/tapped.
the raised pad to the right of it IS on my motor. Question is how do i get there from here.....
Old 09-16-2015, 07:45 AM   #4
LDO
LDO's Avatar
Anyone have any ideas?
Old 09-16-2015, 09:21 AM   #5
geezer#99
geezer#99's Avatar
Why do you need heat shields?
Old 09-16-2015, 02:19 PM   #6
1963c-10
1963c-10's Avatar
Why not drill and tap the area in question?
1964 Short bed trailer
Old 09-16-2015, 03:15 PM   #7
vidman
vidman's Avatar
Talking Re: Heat sheild help
Thats what i would do..Drill and tap the boss that has no ho in it...
62 Willys 4wd Pickup : 72 C-10 swb 504 stroker 09 Taco 3" lift 33" tires: 90 K-5 blazer (plow truck): RIP Ross Little brother
vidman is offline   Reply With Quote
Old 09-16-2015, 03:52 PM   #8
LDO
LDO's Avatar
Because i am a big chicken and afraid of messing up my new motor. Lol
Old 09-17-2015, 11:42 AM   #9
1963c-10
1963c-10's Avatar
Place the bracket where it goes.....mark with a marker. Use a punch and dimple the spot. Drill the appropriate length, tap and your home free.
Old 09-17-2015, 11:52 AM   #10
LDO
LDO's Avatar
I assume since the pad is there, it should be just that easy right?
Old 09-17-2015, 12:42 PM   #11
The Rocknrod
Moderator
The Rocknrod's Avatar
If the raised pad is there your home free. Just don't drill "through" the block. Measure the depth of the other one, use a drill stop or a Marker (Sharpie) on the drill bit.
Old 09-17-2015, 04:27 PM   #12
cv65
cv65's Avatar
L think you maybe are little confused where the shields bolt up,look at this 327 and see if it helps ,I may be confused but before you drill holes in your block take a look, http://www.thecairns.com/Impala/engine.html
cv65 is offline   Reply With Quote
Old 09-17-2015, 05:25 PM   #13
The Rocknrod
Moderator
You could be very correct. The forward Driver side and the rear passenger side isn't clear though.
Old 09-17-2015, 06:32 PM   #14
LDO
LDO's Avatar
Maybe I've got my placement off or maybe the wrong year shields (if there is such a thing).
Here is my motor...
Driver side looks fine and everything lined up.
Next pics show the passenger side of block. Empty boss on the left, threaded boss on the right.
Old 09-17-2015, 07:14 PM   #15
cv65
cv65's Avatar
man got me stumped,maybe a different shield,I think before I drilled my block I would fab up a sheetmetal cure for the bracket you have and make the existing hole work,just my 2 cents
Old 09-17-2015, 07:23 PM   #16
LDO
LDO's Avatar
That's what I was thinking. Maybe a 'connector' bracket for the bracket on the shield.
I am using straight boot wires and running them along the top of the VCs so I feel the shields will help.
Old 09-18-2015, 12:44 AM   #17
Captainfab
60-66 Nut
That's what I would do. Just make up a short bracket from say 1/8" x 3/4 or 1" to bolt to the block and move your heat shield where it needs to be.
Old 09-18-2015, 07:35 PM   #18
LDO
LDO's Avatar
Thanks for all the advice folks. Came home early from work and got it done.
Not too shabby for a guy with little metal-working skills. LOL
Old 09-18-2015, 08:05 PM   #19
cv65
cv65's Avatar
"OOH RA" looks like it was made that way!
