Old 02-27-2015, 12:05 PM   #76
GRADYS Performance
GRADYS Performance's Avatar
Re: Ask me anything about a 4L80e swap using standalone controller
Here is a picture of the 4L80E transmission I installed in my truck with the mechanical speedometer tailhousing.
GRADYS Performance is offline   Reply With Quote
Old 02-27-2015, 05:22 PM   #77
watahyahknow
watahyahknow's Avatar
Originally Posted by slimneverdies View Post
I was hoping there were some aftermarket gauges that just plug into the tci unit from the trans. Don't they make autometer gauges with the elec signal? If I'm going to pay $300+ For a cable x box I would rather get new gauges if that's possible.
like i said you need to find out the year and make of the truck the trans came out of , maibe even take the speedo out of THAT truck
that should work if the end drive is the same in the rear diff
if youre handy and have small fingers / fine motorskills you might be able to build the mecanics of the electronic speedo intoo the housing of youre old mecanical speedo
there usually just hold to the facia plate with two tiny screws
i got a job again and having fun at it too
idea's for the trucks and the order of things to do are taking shape and get closer to being realized , a few more months and i be able to start building for real
i complete 2 of the trucks intoo running fashion one custom and one basicly stock the thirth will be sacrificed for parts
watahyahknow is offline   Reply With Quote
Old 02-27-2015, 09:35 PM   #78
slimneverdies
slimneverdies's Avatar
I wanted to keep it kinda of simple watahyaknow. I was thinking something more in line with this
http://www.autometer.com/5-speedo-16...a-lite-ii.html
Or
http://www.dakotadigital.com/index.c...rod/prd783.htm
It looks like they have all the connections that's needed to tie into a late model tranny. Mine is a 2004 if that helps any...
Long live SLIM
At least try to buy American
slimneverdies is offline   Reply With Quote
Old 02-28-2015, 09:21 AM   #79
solidaxel
solidaxel's Avatar
If I had a extra 800$ that would be in my 78 truck 1 day after the UPS truck left the driveway.
D D sure has some nice "stuff"
We are putting that similar D D set up in a 46 Chevy truck, they address everything in one set!!
53 TuTone Extended Cab 350 4-Spd 3:08 (SOLD)
53 Chevy Moldy pearl green ZZ-4 4L60E 9" 3:25
55 GMC 1st Black Mll (ZZ4) ZZ6 TKO 600 5 sp 3:73
62 Solidaxle Corvette Roman Red (327
340hp 4spd 3:36) C4 & C5 suspension tube chassis
LS 3 4L70E
65 Corvette Coupe 327 350hp 4spd 4:11
78 Black Silverado SWB (350/350) 5.3 & 4L60E 3:42
2000 S-Type 3.0 (wife cruiser)
2003 GMC SCSB 5.3 4L60E 3:42
solidaxel is offline   Reply With Quote
Old 09-18-2015, 04:55 PM   #80
funkatation
I am getting everything to do the swap in my 74 GMC 1/2 ton. Will my Th400 cooler lines work or do I need to get different ones?
funkatation is offline   Reply With Quote
Old 09-19-2015, 04:25 AM   #81
bilfman
bilfman's Avatar
I was able to use my original th400 lines with a little re-tweaking.
1979 Chevy Dually Crew 4X4 454, D60 Tru-trac, D70 Detroit Locker, 3.73, 4L80E/NP205
1971 GMC 3/4 Ton 4X4
bilfman is offline   Reply With Quote
Old 09-19-2015, 10:53 AM   #82
funkatation
If it helps, I'm getting a 93-97 model where both cooler lines are up front.
