factory a/c on a 350
I recently bought a 1970 GMC, it has factory a/c on the orig 396. I want to pull the 396 and put in a 350. Does anyone know if I can use the factory a/c without to many modifications?
the 350 compressor mounts on the passenger side....
if thats where yours is at then all you need are the brackets... by the way...your big block brackets will bring a good buck... ![]() |
ok here's my after market sanden comp. on my 350
my compressor is mounted with allen grove brackets.....
that compressor sell's for about 200.00 new.. but i bought it used with the brackets for 110.00 shipped from smonty......GREAT GUY BY THE WAY...... two bolts and it off...... pull one bolt and the belt it lays back..... no need to do anything to remove the valve cover ![]() |
I dont see much wrong with having a 396 for a spare either. BB ac brackets are sought after ... me included. I have a partial set of SB ones for trading partially if interested.
As for the swap... I think you may need only sb brackets, correct sb pullies for ac .... hmm I can help you there also. Anyway... good luck on the swap. Rod
Senior active founding member. 70 3/4 ton GMC Suburban 4x4 250/4 spd. 71 1/2 ton Suburban Chevy 4x4, 350/350 72 Chev 1 ton tow truck 402BB w/Holmes 440 wrecker on propane 2005 FLSTSCI Harley Springer 85 FXSB Harley Lowrider 72 Triumph 650 Bonneville 5spd "Poor people don't have hobbies" Quote from wife. |
Say..Rage'n......you're cool pretty good?
#7 | |
just got it all together...going to change out two more o-rings and they all will be replaced...the old one's were hard as rocks... going with r134...thats what the compressor is rated for... i hear that it's never going to be as good as r12 but it got to be better than sitting in a 100 degree truck ![]() |
KEEP THE BIG BLOCK!
Tim |
![]() Join Date: Feb 2003
BBC A/C brackets
Did all of the BBC's have the compressor mounted on the drivers side ? How about the BBC's for 67-72 ? .......Thanks.....Zoomy
Mike
My 71 has the big block with ac on passenger side.
70'c/10, 71 suburban4x4 402bb, 72suburban 4/6 drop, 72k/5 4x4 blazer 4" lift 35 tires |
